Date/Time: Sat, 23 Nov 2024 07:53:15 +0000
Volume profile
View Count: 1941
[2013-06-26 18:19:35]
User28682 - Posts: 233
Hi all. Yesterday I asked how I could make a volume only profile? I was told I needed to throw the attached file into the SC data folder to do it. It turns out this file is not windows friendly, at least I cant get to it. Can anyone make it windows friendly?
Tom
attachmentvp_oh.StdyCollct.zip - Attached On 2013-06-26 18:19:18 UTC - Size: 477 B - 774 views
[2013-06-26 22:19:56]
Sawtooth - Posts: 4118
Go here and download this zip file extractor:
http://download.cnet.com/7-Zip/3000-2250_4-10045185.html
Then put the unzipped file in your Sierra Chart \Data folder
[2013-06-28 01:48:23]
Here are the instructions to work with a Study Collection file:
http://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html#SC
You first need to unzip this file. You should be able to unzip it just by opening the file within Windows Explorer.
