Date/Time: Sat, 23 Nov 2024 07:41:59 +0000
SC 991 :problem of access denied
View Count: 1580
[2013-06-26 08:45:15]
salsem - Posts: 43
Hi SC Support,
I have 2 pc with SC, also waiting for 3/5 minutes, the access is denied me.
I connect with SC with a PC at a time
waiting for reply
Thanks in advance
imagesierra chart login.jpg / V - Attached On 2013-06-26 08:45:04 UTC - Size: 86.77 KB - 632 views
[2013-06-26 10:17:55]
Your account is through a broker and therefore that account can only be used on one computer system at a time.
For additional systems you need a direct account. Follow the instructions here:
https://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html
