Date/Time: Sat, 23 Nov 2024 07:53:27 +0000
multiple timeframes one chart
View Count: 2363
[2013-06-25 16:17:24] |
saxo12 - Posts: 38 |
1/came across a chart that had 15mins(high/low/close/open) inside 30min candle bars does anyone know if sierra can do this https://d1yoaun8syyxxt.cloudfront.net/gk104-oagruyhovuivjtslrhqlgxzahpucdyey-v2 2/is it possible to get multiple timeframes on one chart, not above each other |
[2013-06-25 16:50:03] |
Sawtooth - Posts: 4118 |
1/ Try the NMinBars user-contributed study on the 15min chart, and set the Seconds Count to 1800. Go to Analysis >> Studies >> Add Custom Study... >> User Contributed Studies >> NMinBars >> Add 2/ Not directly. Try the Study/Price Overlay study and set the Scale to Independent. |
[2013-06-25 23:06:07] |
Please refer to help topic 28 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
