Date/Time: Sat, 23 Nov 2024 07:34:16 +0000
Keyboard shortcut problem
View Count: 1533
[2013-06-25 06:39:45] |
joshtrader - Posts: 488 |
I use F7/F8 to scroll workspaces. If a chart has focus, it works fine. But if I switch to a workspace and a spreadsheet tab has the default focus, the F7/F8 keys don't work.
[2013-06-25 17:42:19] |
Yes, we do see this as well. This will be resolved in a couple of months.
