Date/Time: Sat, 23 Nov 2024 07:18:42 +0000
Can't view Russell 2000 intraday - only historical
View Count: 1662
[2013-06-25 04:12:33] |
User56097 - Posts: 5 |
I am trying to view the Russell 2000 intraday chart, however I am unable to when I try to open a new chartbook. The only thing that will open is the historical daily data. I am just using the SC data (no broker) but I thought I would be able to view the Russell still. I have tried both the TF symbol and the RJ symbol without any luck. Any help would be greatly appreciated. |
[2013-06-25 17:35:45] |
You need to use the service named "SC Historical Data". Please follow the instructions on this page: https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html The symbol begins with RJ. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
