Date/Time: Sat, 23 Nov 2024 07:52:12 +0000
daily chart rollover
View Count: 2106
[2013-06-24 16:15:56]
M5amhan - Posts: 468
i just rolled soybeans from ZSN3 to ZSX3
http://www.sierrachart.com/image.php?l=1372090520868.png
how do i fix this?
edit: i have done delete and download data & download data - historical chart
thanks
Date Time Of Last Edit: 2013-06-24 16:17:56
[2013-06-24 17:44:47]
Uncheck the Continuous Futures Contract option in Chart >> Chart Settings . The transition to the current contract may not have occurred at the expected time.
Date Time Of Last Edit: 2013-06-24 17:45:42
[2013-06-24 17:56:31]
will this be fixed at some point? i need continuous contract or else i wouldnt use it
[2013-06-25 13:04:13]
is this going to get fixed?
[2013-06-25 17:24:56]
We are checking on this today.
[2013-06-27 00:04:06]
has there been any solution for this?
edit: here is an updated chart of how its plotting previous day's bars -- http://www.sierrachart.com/image.php?l=1372292236313.png
p.s. sorry for lines cant delete those
Date Time Of Last Edit: 2013-06-27 00:18:20
[2013-06-27 00:57:05]
We see the problem and it will be resolved tomorrow.
[2013-06-28 01:59:27]
hello
just an update on this, it is plotting differently but still not correctly.
it looks like it is plotting ZSN3 ZSQ3 and ZSX3 all on the same price axis: http://www.sierrachart.com/image.php?l=1372384694191.png
[2013-06-28 03:10:29]
We have done some changes. But the problem is ZSQ3 and ZSX3 are not both expired and you are charting ZSX3. So it is difficult to create a Continuous Futures Chart.
We are going to put out a new release in about 20 minutes. The version number is the same.
[2013-06-28 03:11:32]
Is ZSQ3 ever an actively traded contract.
[2013-06-28 03:25:12]
no the august contract is always less volume than november is
