Date/Time: Sat, 23 Nov 2024 07:45:22 +0000
Error 5 on compiler
View Count: 1611
[2013-06-23 14:33:15]
User57124 - Posts: 48
I have a cpp study this is my first time using Sierra compiler and I got this error. Is this due to my Windows virus ware? How do i fix?
thx in advance R
[2013-06-23 20:36:32]
We need to see a copy of the Build Output from the Build Custom Studies DLL window. Select the text in that window and select Copy and Paste it here.
[2013-06-25 12:46:51]
yesterday i tried to download new version of Sierra got Error 5 again
[2013-06-25 17:31:10]
So you mean you got this error when you selected Help >> Download Current Version?
If so, please provide a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2013-06-25 17:50:20]
Yes when i tried to download current version for update I received Error 5.
Software version: 976 | 2013-06-24 19:29:19
Current Service Package: 5 | 2013-06-24 19:29:19
Usage end date: 2013-07-23 | 2013-06-24 19:29:19
Sierra Chart Historical Data Service is included. | 2013-06-24 19:29:19
Active service: Rithmic 01 | 2013-06-24 19:29:19
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-06-24 19:29:19
2013-06-24 19:29:19 Local computer clock time | 2013-06-24 19:29:19
2013-06-24 23:29:19 GMT time | 2013-06-24 19:29:19
2013-06-24 19:29:19 Time zone adjusted time | 2013-06-24 19:29:19
Time difference to server time: 3 seconds. | 2013-06-24 19:29:19
Program path: C:\SierraChart\ | 2013-06-24 19:29:19
Data Files path: C:\SierraChart\Data\ | 2013-06-24 19:29:19
OS Version Number: 6.1 | 2013-06-24 19:29:19
Rithmic service: Connecting. | 2013-06-24 19:29:25
Rithmic logging is enabled. Log file path: C:\SierraChart\Logs\Rithmic.log | 2013-06-24 19:29:25
Using Rithmic Production server. | 2013-06-24 19:29:25
Rithmic Alert Message - Market Data Connection Opened. | 2013-06-24 19:29:26
Rithmic Alert Message - Market Data Connection Login Complete. ok | 2013-06-24 19:29:26
Rithmic Alert Message - Trading System Connection Opened. | 2013-06-24 19:29:26
Rithmic Alert Message - Trading System Connection Login Complete. ok | 2013-06-24 19:29:26
Account information received. | 2013-06-24 19:29:26
Rithmic service - FCM: Vision | 2013-06-24 19:29:26
Rithmic service - IB: OptimusFutures | 2013-06-24 19:29:26
Rithmic Alert Message - PnL Connection Opened. | 2013-06-24 19:29:26
Rithmic Alert Message - PnL Connection Login Complete. ok | 2013-06-24 19:29:26
Rithmic Alert Message - Intraday History Connection Opened. | 2013-06-24 19:29:27
Rithmic Alert Message - Intraday History Connection Login Complete. ok | 2013-06-24 19:29:27
Rithmic service: Connected. | 2013-06-24 19:29:27
A request for the latest software update has been made. | 2013-06-24 19:29:38
Downloading... You can continue to work during the download. | 2013-06-24 19:29:38
Failed to open the file: C:\SierraChart\SierraChartSetup.exe. Windows error code 5: Access is denied. | 2013-06-24 19:29:46
A request for the latest software update has been made. | 2013-06-24 19:32:05
Downloading... You can continue to work during the download. | 2013-06-24 19:32:05
Failed to open the file: C:\SierraChart\SierraChartSetup.exe. Windows error code 5: Access is denied. | 2013-06-24 19:32:13
Date Time Of Last Edit: 2013-06-25 21:00:38
[2013-06-25 20:49:41]
Sierra Chart - Max - Posts: 5730
Please restart/reboot your computer, start Sierra Chart and then select "Help >> Download Current Version".
Sierra Chart Support
Date Time Of Last Edit: 2013-06-25 21:01:26
[2013-06-25 21:02:12]
If after restarting you still have this error, then you need to disable your anti-malware software. And also have the anti-malware software completely exclude the folder that Sierra Chart is installed to.
