DTC Protocol Discussion Forum
Date/Time: Mon, 15 Dec 2025 09:10:57 +0000
[OrderUpdate] ORDER_FILLED_PARTIALLY: matching OrderStatusEnum ?
View Count: 3227
[2015-09-10 12:24:00]
vbmithr - Posts: 204
I can't find a OrderStatusEnum matching the reason ORDER_FILLED_PARTIALLY.
In case of a partial fill, what should I set in the OrderStatusEnum field ?
[2015-09-10 13:00:03]
Maybe there should be a PARTIALLY_FILLED value in OrderStatusEnum ??
[2015-09-11 00:20:06]
DTC Engineering - Posts: 320
The matching OrderStatusEnum is ORDER_STATUS_OPEN. And the FilledQuantity field indicates the amount that has filled.
So it is possible to clearly determine if the order is partially filled.
[2015-09-11 00:28:02]
We are considering adding a "PartiallyFilled" status .
Date Time Of Last Edit: 2015-09-11 00:28:42
[2015-10-08 14:00:15]
No update on this?
It's probably not that useful, as you said.
[2015-10-09 20:59:13]
We can add this, but effectively there is no benefit to it.
It is very easy to tell whether order is partially filled by simply looking at its order quantity, filled quantity and order status.
[2015-10-10 09:20:14]
This Order Status has now been added to the DTC protocol:
ORDER_STATUS_PARTIALLY_FILLED = 10
The new files will be released before Monday.
