Date/Time: Sat, 23 Nov 2024 11:26:53 +0000
Message: More than 5% difference ....
View Count: 1836
[2013-06-14 11:07:55]
flyboy615 - Posts: 56
I'M trying to track down a bug in someone's code. The message I receive once in a while in an automated system is as follows:
More than 5% difference when calculating new trailing order Price1. Order not modified.
What is the meaning of this message found in the trade service log ant any idea of the potential causes?
[2013-06-14 17:51:09]
This means that the new price calculated for a Stop order is more than 5 percent different than the current price, so the order is not modified.
The calculations are based upon the last trade prices.
[2013-07-03 01:04:51]
User23815 - Posts: 210
Here is more info as requested. This describes my stop type and should give the info requested.
I am using a Triggered Trailing Stop with a MBE type: Offset in Ticks Triggered.
My spreadsheet system uses the Trade Management by Study study to modify the Attached Orders' stop.
[2013-07-03 20:05:26]
If you are using Trade Management by Study with a trailing stop, that can definitely cause problems if the study Subgraph it is based upon is moving the stop to unreasonable levels. You should not be using this on a trailing stop. In general, that does not even make sense.
You are making things too complicated. You are using a Triggered Trailing stop, you are modifying it by a study and also have a Move to Breakeven setting on it as well.
Date Time Of Last Edit: 2013-07-03 20:06:32
