Date/Time: Sat, 23 Nov 2024 21:02:45 +0000
[Locked] - Announcement: Long-Term Development Plans to Support Other Operating Systems
View Count: 2177
[2015-08-25 04:59:29] |
For at least the last two years, we have been talking about changing Sierra Chart to run natively on Mac and Linux systems. We have been gradually working towards this, and we have mentioned that we may have this done in 2015. This clearly will not be the case. At this time, we do not want to make a promise as to when this will be done. There should not be a reliance on this happening at any particular point in time because it is a long-term effort. While we have been working towards this objective, we have not been working full-time on this effort and working on it in earnest. Gradually we are making progress with all the aspects of accomplishing this so that it can be done properly, and that the final result will be fast, efficient and reliable. This is not an easy objective. Under no conditions, will we do anything to affect the general performance and look and feel of Sierra Chart. So should you expect something in 2016? Possibly but once again we cannot make that promise and there should not be a reliance on it. The very first step is to port Sierra Chart over to a different development framework and get it running within that framework on Windows. That will be the first thing that you will see. Another thing, is that longer-term the interface to Excel may no longer be available. So there should not be long-term reliance on that. We will keep it as long as we can, but possibly in a year or two it may not be available in newer versions. The Sierra Chart built-in Spreadsheets will always be available. What we are talking about is the "Use Excel" setting with the Spreadsheet study. A couple of additional points, and we will say this publicly, for the connectivity to TransAct and Rithmic, we hope those are direct connections to servers and no longer use bridge programs. So this will require changes by both of these companies to provide us direct connections. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-25 05:02:38
[2015-11-12 01:32:06] |
We want to provide an update on this. While we have gradually been making changes in Sierra Chart in order to make it easier to port Sierra Chart to other operating systems, the major work to actually make this happen has not begun in earnest. The basic reason, is we are not sure what development framework to use. We have contemplated using QT. But this is a very scary step. It could be a disastrous mistake that hurts the performance of Sierra Chart, the look and feel of Sierra Chart, cause lots of small problems for users, and can cause us an awful lot of wasted time and frustration. None of this is good. So basically whether Sierra Chart is going to support other operating systems, yes eventually this will happen, but when is a huge unknown. We do not think it will come in 2016. The safest thing that we might decide to do is to support Mac or Linux and not both of them. And do the necessary work to interface to the appropriate APIs for one of those. This would bypass the development framework like QT altogether. For a high-performance program like Sierra Chart, in order for it to maintain its consistency, speed and reliability and at the same time support other operating systems, it is not entirely possible. These two objectives compete with each other and this is the basic fundamental problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-11-12 01:38:07
