Date/Time: Sat, 21 Dec 2024 18:29:34 +0000
Auto Fibonacci drawings
View Count: 1537
[2015-07-30 13:38:24] |
Netz - Posts: 19 |
Hello. I was wondering if there is an option to set the Auto Fibonacci Study to just show the drawings for the current period only? I have levels set to dash drawing style. The way I have it now, it shows the levels for past periods, which clutters my charts. Thanks for your advice. Regards, |
[2015-07-30 17:59:00] |
No there is not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-30 17:59:57
