Date/Time: Sat, 21 Dec 2024 18:36:30 +0000
hi support..
View Count: 1121
[2015-07-28 20:09:24] |
User53765 - Posts: 66 |
Just a question or request please. I notice on the Trade DOM under graphic settings there is ``Chart trade window background LIVE & SIM`` variations and adjustability to each`s own. My question is or to make a request to ask if this same feature can be added only to the Trade DOM LIVE & SIM if someone is just using the Trade DOM without the Chart trade side. Thanks in advance. |
[2015-07-29 18:20:52] |
What do you mean by "chart trade side"? Are you referring to the attached Trade Window?
[2015-07-29 18:24:01] |
That is correct im referring to the ``attached trade window``. I was wondering if the same flexibility of changing the background color from LIVE to SIM could be done on the Trade DOM on its own. That was my requrest or question. Thanks. |
[2015-07-30 19:35:11] |
No, this is not supported because the background of the Trade DOM window has other color settings which would conflict.
