Date/Time: Sat, 21 Dec 2024 18:12:10 +0000
Quote board settings
View Count: 967
[2015-07-25 21:19:33]
User726098 - Posts: 23
Is there anyway to modify the quote board box? I would like to be able to remove the title bar to make the box smaller or even the settings line so they dont show. Only thing that i see is to modify text size for quote board as far as the box size.
Resason being is that after upgrading to 1276 seems as if my alignment of my chart windows were changed. I had to pull them down a bit to fit my screen and the quote board now overlapps my chart view. I would have to drag it all the way to tthe top of the screen until the title disappears so it doesnt block the chart. By having the option to remove the title bar would give me the space i need so it would not block my chart.
Date Time Of Last Edit: 2015-07-25 21:27:49
[2015-07-25 21:46:44]
There is no way to do what you requested with the Quote Board.
