Date/Time: Sat, 21 Dec 2024 18:37:42 +0000
How to disabled Box info for retracement
View Count: 773
[2015-07-23 12:33:59] |
User33743 - Posts: 83 |
For version 1276, after drawing fibo retracement appears Box. How can i disable that box so when drew next time retracement it will not appear?
Screenshot_3.png / V - Attached On 2015-07-23 12:33:39 UTC - Size: 21.37 KB - 288 views |
[2015-07-23 17:39:18] |
tobi - Posts: 351 |
This is the "Compact Tool Values Window". You can uncheck / disable it here: Window >> Show Compact Tool Values Window
[2015-07-23 18:42:11] |
Yes. Uncheck Window >> Show Compact Tool Values Window .
