Date/Time: Sat, 21 Dec 2024 18:09:51 +0000
SIM account in DOM?
View Count: 874
[2015-07-19 20:51:05] |
User948305 - Posts: 21 |
Hi, I just start free trial today. My broker is IB. After I setup and connect to IB successfully, I only see SIM in DOM window. Is this the restriction in free trial period? thanks, |
[2015-07-19 20:56:45] |
ok, I guess I have to uncheck 'Trade Sim ON' from menu.
[2015-07-20 00:08:26] |
Yes. This is correct.
