Date/Time: Sat, 21 Dec 2024 18:27:46 +0000
tick by tick data NQ trial
View Count: 1839
[2015-07-18 18:11:57]
User428317 - Posts: 5
Hi support board,
I was curious about the numbers bar provided by sierra data fee, so I downloaded sierra chart with SC historical data. When I opened the NQ numbers bar chart, I have seen number bars where every only fifth tick was populated by tick by tick value. All others were empty. Is there any way to fix it so I can see all tick by tick values? Thank you. Screen shot attached for your perusal.
Thank you
image20150718 14 07 04.jpg / V - Attached On 2015-07-18 18:11:03 UTC - Size: 310.99 KB - 422 views
image20150718 14 07 24.jpg / V - Attached On 2015-07-18 18:11:11 UTC - Size: 119.53 KB - 394 views
image20150718 14 07 37.jpg / V - Attached On 2015-07-18 18:11:16 UTC - Size: 159.42 KB - 366 views
image20150718 14 09 20.jpg / V - Attached On 2015-07-18 18:11:21 UTC - Size: 371.76 KB - 405 views
[2015-07-18 20:51:05]
We only needed a single image of the chart and this is the procedure to attach a chart image:
Set the Chart >> Chart Settings >> Volume at Price Multiplier to 1.
Date Time Of Last Edit: 2015-07-18 20:52:24
