Date/Time: Sat, 21 Dec 2024 17:58:27 +0000
VbP Study Values
View Count: 898
[2015-07-16 18:09:09] |
Johnny - Posts: 99 |
Hello, I would like to make a recommendation regarding the VbP study. Is it possible to add the Point of Control volume to the VbP chart values? Also, is it possible to access these values through ACSIL, volume above/below POC in particular? Thanks |
[2015-07-24 16:22:54] |
Support, have you seen my message?
[2015-07-28 05:40:36] |
Yes. But we cannot get to these now.
