Date/Time: Sat, 21 Dec 2024 18:38:29 +0000
[User Discussion] - Next bar rage on Flex renko
View Count: 920
[2015-07-16 15:55:59]
Locomotora - Posts: 14
I am trying to draw the open and close line for a "future" flex renko bar, (possible bullish and possible bearish) and i am using spreadsheet for this. Is there a way to limit the calculation ONLY to the last bar? I don't need to see this information for previous bars. I have tries to change the spreadsheet settings but it only allows 10 rows minimum. Any help??
[2015-07-16 16:25:15]
Sawtooth - Posts: 4141
Use a formula like this:
=IF(ROW()=3,yourconditions,0)
[2015-07-16 17:16:48]
Thanks for your help. I almost get it done but the chart got all messed up.
=IF(ROW()=3,B4<E4,C4+5)
condition in this case is if open < close, draw a dash at C (high + 5 ticks.
my chart looks a mess.
[2015-07-16 17:23:20]
sorry, i just read the Format: IF(Condition, TrueValue, FalseValue)
[2015-07-16 19:27:11]
Try this:
=IF(ROW()=3,IF(B4<E4,C4+5*$J$21,0),0)
This would also work:
=IF(AND(ROW()=3,B4<E4),C4+5*$J$21,0)
