Date/Time: Sat, 21 Dec 2024 18:05:54 +0000
adware.win32.conduit.BP
View Count: 1059
[2015-07-15 14:56:01] |
User407131 - Posts: 1 |
After downloading Sierra chart from your download page, Baidu antivirus scanned and warned me not to open the file as it contains the nasty Trojan virus: adware.win32.conduit.BP. Any ideas why?
[2015-07-15 16:54:48] |
What executable program did it report this for? You can safely disregard it. The software is clean. It could not contain anything like that. Sometimes anti-virus/anti-malware programs will report false positives. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
