Date/Time: Sat, 21 Dec 2024 18:33:47 +0000
Symbol: ND#
View Count: 1046
[2015-07-15 14:54:16] |
User138602 - Posts: 169 |
Hello, Historical Chart shows only 3 trading days for last week. And this week only 1 daily bar gets drawn. I downloaded several times,...no change. Is there a new nasdaq100 symbol or whats going on? Date Time Of Last Edit: 2015-07-15 14:54:29
[2015-07-15 17:12:10] |
We recommend using the symbol NQ# instead.
