Date/Time: Sat, 21 Dec 2024 18:27:43 +0000
Global data feed log-in problem
View Count: 1932
[2015-07-15 04:29:04] |
ashjal714 - Posts: 9 |
Hi, I am using trial version of Sierra charts and today I have subscribed for Global data feed (India) for charts but I am unable to login. Please help on this matter urgently. Below is the log:- Global Data Feeds (India) | 56000 | 2015-07-15 09:52:20 GDF FIX Data socket (15) | Connected. | 2015-07-15 09:52:20 GDF FIX Data: Sending the Logon message. | 2015-07-15 09:52:20 GDF FIX Data: Sent heartbeat to server. | 2015-07-15 09:52:50 Service connection timed out. Will disconnect and retry. | 2015-07-15 09:53:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 09:53:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 09:53:20 GDF FIX Data: DisconnectFIX called. | 2015-07-15 09:53:20 GDF FIX Data: Sending a Logout message. | 2015-07-15 09:53:20 Disconnected from GlobalDataFeeds. | 2015-07-15 09:53:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 09:53:20 GDF FIX Data: Waiting for Logout response timed out. Closing the socket now. | 2015-07-15 09:53:24 * GDF FIX Data socket (15) | Shutdown and closed. | 2015-07-15 09:53:24 GDF FIX Data: Socket closed without completing the logout sequence. | 2015-07-15 09:53:24 Global Data Feeds (India) | 56000 | 2015-07-15 09:53:25 GDF FIX Data socket (16) | Connected. | 2015-07-15 09:53:25 GDF FIX Data: Sending the Logon message. | 2015-07-15 09:53:25 GDF FIX Data: Sent heartbeat to server. | 2015-07-15 09:53:55 Service connection timed out. Will disconnect and retry. | 2015-07-15 09:54:25 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 09:54:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 09:54:25 GDF FIX Data: DisconnectFIX called. | 2015-07-15 09:54:25 GDF FIX Data: Sending a Logout message. | 2015-07-15 09:54:25 Disconnected from GlobalDataFeeds. | 2015-07-15 09:54:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 09:54:25 GDF FIX Data: Waiting for Logout response timed out. Closing the socket now. | 2015-07-15 09:54:29 * GDF FIX Data socket (16) | Shutdown and closed. | 2015-07-15 09:54:29 GDF FIX Data: Socket closed without completing the logout sequence. | 2015-07-15 09:54:29 Global Data Feeds (India) | 56000 | 2015-07-15 09:54:30 GDF FIX Data socket (17) | Connected. | 2015-07-15 09:54:30 GDF FIX Data: Sending the Logon message. | 2015-07-15 09:54:30 GDF FIX Data: Sent heartbeat to server. | 2015-07-15 09:55:00 Service connection timed out. Will disconnect and retry. | 2015-07-15 09:55:30 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 09:55:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 09:55:30 GDF FIX Data: DisconnectFIX called. | 2015-07-15 09:55:30 GDF FIX Data: Sending a Logout message. | 2015-07-15 09:55:30 Disconnected from GlobalDataFeeds. | 2015-07-15 09:55:30 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 09:55:30 GDF FIX Data: Waiting for Logout response timed out. Closing the socket now. | 2015-07-15 09:55:34 * GDF FIX Data socket (17) | Shutdown and closed. | 2015-07-15 09:55:34 GDF FIX Data: Socket closed without completing the logout sequence. | 2015-07-15 09:55:34 Global Data Feeds (India) | 56000 | 2015-07-15 09:55:35 GDF FIX Data socket (18) | Connected. | 2015-07-15 09:55:35 GDF FIX Data: Sending the Logon message. | 2015-07-15 09:55:35 File >> Disconnect selected. | 2015-07-15 09:55:38 GDF FIX Data: DisconnectFIX called. | 2015-07-15 09:55:38 GDF FIX Data: Sending a Logout message. | 2015-07-15 09:55:38 Disconnected from GlobalDataFeeds. | 2015-07-15 09:55:38 GDF FIX Data: Waiting for Logout response timed out. Closing the socket now. | 2015-07-15 09:55:42 * GDF FIX Data socket (18) | Shutdown and closed. | 2015-07-15 09:55:42 GDF FIX Data: Socket closed without completing the logout sequence. | 2015-07-15 09:55:42 Date Time Of Last Edit: 2015-07-15 04:47:41
[2015-07-15 05:49:53] |
Did Global Data Feeds provide you a server address and port number to connect to? If so what are they? Select Global Settings >> Data/Trade Service Settings. Set the Connection Details >> Server to the following: 180.179.67.120:8086 This is what it should be unless they have given you a different server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-15 05:50:03
[2015-07-15 05:53:38] |
Please find the attached image showing IP and port provided by Global datafeed..
IP and port.png / V - Attached On 2015-07-15 05:52:40 UTC - Size: 15.08 KB - 368 views Attachment Deleted. |
[2015-07-15 06:44:56] |
I have tried with the below IP and port:- 180.179.67.120:8086 now getting recon wait message. Please help on this. |
[2015-07-15 10:26:31] |
In response to post #3, those IP addresses and port numbers are not valid for the Global Data Feeds FIX connection. We need to see the Message Log again which shows the current connection problem you are having. Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-15 10:27:50
[2015-07-15 13:13:07] |
Please find below the message log for your reference:- Software version: 1269 | 2015-07-15 18:37:43 Uses New Spreadsheets | 2015-07-15 18:37:43 Usage end date: 2015-07-29 | 2015-07-15 18:37:43 Enabled for: Advanced Features. | 2015-07-15 18:37:43 Enabled for: Advanced Features 2. | 2015-07-15 18:37:43 Enabled for: Sierra Chart Historical Data Service. | 2015-07-15 18:37:43 Allow Support for Sierra Chart Data Feeds is disabled. | 2015-07-15 18:37:43 Active service: Global Data Feeds (India) | 2015-07-15 18:37:43 Time Zone: +05:30:00 (IST+05:30) | 2015-07-15 18:37:43 2015-07-15 18:37:43 Local computer clock time | 2015-07-15 18:37:43 2015-07-15 13:07:43 GMT time | 2015-07-15 18:37:43 2015-07-15 18:37:43 Time zone adjusted time | 2015-07-15 18:37:43 Time difference to server time: 82 seconds. | 2015-07-15 18:37:43 WARNING: Your computer's clock is off by 82 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2015-07-15 18:37:43 Program path: C:\SierraChart\ | 2015-07-15 18:37:43 Data Files path: C:\SierraChart\Data\ | 2015-07-15 18:37:43 OS Version Number: 6.1 | 2015-07-15 18:37:43 Locale Information: C | 2015-07-15 18:37:43 Checking for new symbol settings for gdf | 2015-07-15 18:37:43 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-07-15 18:37:43 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-07-15 18:37:44 Symbol settings are up-to-date for gdf | 2015-07-15 18:37:44 Global Data Feeds (India) | 8086 | 2015-07-15 18:38:21 GDF FIX Data socket (8) | Connected. | 2015-07-15 18:38:21 GDF FIX Data: Sending the Logon message. | 2015-07-15 18:38:22 GDF FIX Data socket (8) | Closed. No error. | 2015-07-15 18:38:22 GDF FIX Data socket (8) | Shutdown and closed. | 2015-07-15 18:38:22 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-07-15 18:38:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 18:38:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 18:38:22 GDF FIX Data: DisconnectFIX called. | 2015-07-15 18:38:22 Disconnected from GlobalDataFeeds. | 2015-07-15 18:38:22 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 18:38:22 File >> Disconnect selected. | 2015-07-15 18:38:26 GDF FIX Data: DisconnectFIX called. | 2015-07-15 18:38:26 Disconnected from GlobalDataFeeds. | 2015-07-15 18:38:26 Date Time Of Last Edit: 2015-07-15 16:50:00
[2015-07-15 16:49:10] |
The connection problem most likely is caused by this: Time difference to server time: 82 seconds. | 2015-07-15 18:37:43 WARNING: Your computer's clock is off by 82 seconds. For help with this Date-Time issue, press the Send for Analysis button. | 2015-07-15 18:37:43 For FIX connections the computer clock needs to be set accurately. Adjust your computer's clock so it is set accurately to the second. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-15 16:49:31
[2015-07-15 17:41:33] |
Clock has been set accuratley, so no warning is coming now. But still I am getting recon wait. Below is the log message:- Software version: 1269 | 2015-07-15 23:07:55 Uses New Spreadsheets | 2015-07-15 23:07:55 Usage end date: 2015-07-29 | 2015-07-15 23:07:55 Enabled for: Advanced Features. | 2015-07-15 23:07:55 Enabled for: Advanced Features 2. | 2015-07-15 23:07:55 Enabled for: Sierra Chart Historical Data Service. | 2015-07-15 23:07:55 Allow Support for Sierra Chart Data Feeds is disabled. | 2015-07-15 23:07:55 Active service: Global Data Feeds (India) | 2015-07-15 23:07:55 Time Zone: +05:30:00 (IST+05:30) | 2015-07-15 23:07:55 2015-07-15 23:07:55 Local computer clock time | 2015-07-15 23:07:55 2015-07-15 17:37:55 GMT time | 2015-07-15 23:07:55 2015-07-15 23:07:55 Time zone adjusted time | 2015-07-15 23:07:55 Time difference to server time: 0 seconds. | 2015-07-15 23:07:55 Program path: C:\SierraChart\ | 2015-07-15 23:07:55 Data Files path: C:\SierraChart\Data\ | 2015-07-15 23:07:55 OS Version Number: 6.1 | 2015-07-15 23:07:55 Locale Information: C | 2015-07-15 23:07:55 Checking for new symbol settings for gdf | 2015-07-15 23:07:55 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-07-15 23:07:55 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-07-15 23:07:55 Symbol settings are up-to-date for gdf | 2015-07-15 23:07:56 Global Data Feeds (India) | 8086 | 2015-07-15 23:08:00 Service is currently connecting. | 2015-07-15 23:08:00 * GDF FIX Data socket (2) | Connected. | 2015-07-15 23:08:01 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-07-15 23:08:01 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-07-15 23:08:01 GDF FIX Data: Sending the Logon message. | 2015-07-15 23:08:01 GDF FIX Data socket (2) | Closed. No error. | 2015-07-15 23:08:01 GDF FIX Data socket (2) | Shutdown and closed. | 2015-07-15 23:08:01 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-07-15 23:08:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 23:08:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 23:08:01 GDF FIX Data: DisconnectFIX called. | 2015-07-15 23:08:01 Disconnected from GlobalDataFeeds. | 2015-07-15 23:08:01 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 23:08:01 Global Data Feeds (India) | 8086 | 2015-07-15 23:08:06 GDF FIX Data socket (3) | Connected. | 2015-07-15 23:08:06 GDF FIX Data: Sending the Logon message. | 2015-07-15 23:08:07 GDF FIX Data socket (3) | Closed. No error. | 2015-07-15 23:08:07 GDF FIX Data socket (3) | Shutdown and closed. | 2015-07-15 23:08:07 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-07-15 23:08:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 23:08:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 23:08:07 GDF FIX Data: DisconnectFIX called. | 2015-07-15 23:08:07 Disconnected from GlobalDataFeeds. | 2015-07-15 23:08:07 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 23:08:07 Global Data Feeds (India) | 8086 | 2015-07-15 23:08:12 GDF FIX Data socket (4) | Connected. | 2015-07-15 23:08:13 GDF FIX Data: Sending the Logon message. | 2015-07-15 23:08:13 GDF FIX Data socket (4) | Closed. No error. | 2015-07-15 23:08:14 GDF FIX Data socket (4) | Shutdown and closed. | 2015-07-15 23:08:14 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-07-15 23:08:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 23:08:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 23:08:14 GDF FIX Data: DisconnectFIX called. | 2015-07-15 23:08:14 Disconnected from GlobalDataFeeds. | 2015-07-15 23:08:14 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 23:08:14 Global Data Feeds (India) | 8086 | 2015-07-15 23:08:19 GDF FIX Data socket (5) | Connected. | 2015-07-15 23:08:19 GDF FIX Data: Sending the Logon message. | 2015-07-15 23:08:19 GDF FIX Data socket (5) | Closed. No error. | 2015-07-15 23:08:20 GDF FIX Data socket (5) | Shutdown and closed. | 2015-07-15 23:08:20 GDF FIX Data: Socket connection was closed without any logout messages sent or received. | 2015-07-15 23:08:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-15 23:08:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-15 23:08:20 GDF FIX Data: DisconnectFIX called. | 2015-07-15 23:08:20 Disconnected from GlobalDataFeeds. | 2015-07-15 23:08:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-15 23:08:20 |
[2015-07-15 18:05:39] |
These are the relevant messages: GDF FIX Data: Sending the Logon message. | 2015-07-15 23:08:19 GDF FIX Data socket (5) | Closed. No error. | 2015-07-15 23:08:20 So what is happening is that when Sierra Chart is sending the Logon message to the Global Data Feeds FIX server, that server is then closing the connection. So you need to contact Global Data Feeds and give them your Sender Comp ID and ask them why the server is closing the connection like this. You can refer them to this posting here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
