Date/Time: Sat, 21 Dec 2024 18:30:20 +0000
About Package
View Count: 754
[2015-07-15 01:15:03] |
User513952 - Posts: 84 |
Hi, I want to use IB as data feed to get stock and future live intra-day and historical data (both time and tick based data) in Sierra, can I use package 1? Thanks |
[2015-07-15 04:07:28] |
Yes you can use Sierra Chart service package 1. However, Interactive Brokers does not provide historical tick by tick data. For what markets do you require historical tick by tick data for? The Sierra Chart data services do offer this for some exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-15 04:27:04] |
I need tick data of all USA stock and futures market (CL, YM,ES,NQ...)
[2015-07-15 05:46:28] |
Therefore, we recommend you use the Sierra Chart Real-time and Historical Exchange Data Feed to get tick by tick data. Here is the documentation for it: Sierra Chart Exchange Data Feed This data feed is fully integrated with Interactive Brokers when using Sierra Chart, so you can use this data feed and trade from your Interactive Brokers account in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
