Date/Time: Sat, 21 Dec 2024 18:10:00 +0000
ES Options
View Count: 915
[2015-07-14 16:03:45] |
Robson - Posts: 76 |
Where can i find symbols for ES options on CME with CTS T4? and can i use mid point for charting?
Date Time Of Last Edit: 2015-07-14 16:08:19
[2015-07-14 16:30:32] |
Sierra Chart - Max - Posts: 5756 |
For details about Options refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#Options For Data Recording Modes refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_RecordingModes.php Sierra Chart Support Date Time Of Last Edit: 2015-07-14 17:00:57
[2015-07-15 04:15:29] |
Options are not supported at this time with CTS FIX. We will look into supporting them as soon as possible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
