Date/Time: Sat, 21 Dec 2024 18:36:57 +0000
ACSIL command for to set Bar Spacing
View Count: 1322
[2015-07-14 13:41:19] |
Marmany - Posts: 307 |
I have a series of charts which all require a different Bar Spacing to that set globally. I know this can be changed manually but would find it a lot more efficient to do this from within a study in a similar manner to sc.Subgraph[].LineWidth. Not able to find a way of achieving this in SC Documentation. Please advise if it is possible. If not could a function be added? Many thanks |
[2015-07-14 20:47:23] |
This is what you need to use: sc.ChartBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-15 06:28:02] |
I tried setting sc.ChartBarSpacing in a study and it did not work. Sierra documentation says sc.ChartBarSpacing is read only. Updated to latest pre-release and received an error message "Initialization error: Error initializingMain window objects. Exception caught creating main MDI window" Re-installed v1261 and sierra works OK. Please advise |
[2015-07-15 18:54:41] |
sc.ChartBarSpacing will be read/write in the next version. This will be solved in the next prerelease: "Initialization error: Error initializingMain window objects. Exception caught creating main MDI window" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
