Date/Time: Sat, 21 Dec 2024 18:23:55 +0000
Automatic Looping
View Count: 800
[2015-07-11 22:41:30] |
mkata - Posts: 103 |
sc.function (ArrayIn, ArrayOut, Length) When setting Length with some number I have no problem. What can I use for Length that would equal TIME_PERIOD_LENGTH_UNIT_DAYS, essentially my session times? |
[2015-07-11 23:03:17] |
There is no value for this and how to do this is far outside the scope of our support.
