Date/Time: Sat, 21 Dec 2024 18:22:44 +0000
WRB Study
View Count: 1234
[2015-07-11 09:36:08] |
Hieronymus - Posts: 51 |
Hello, can any user edit the WRB study so it uses the real body of candle and not the whole range? I'll gladly pay, thanks.
Date Time Of Last Edit: 2015-07-11 22:08:32
[2015-07-13 20:41:31] |
Yes. This is the Wide Range Bar study you are referring to. In the latest prerelease of Sierra Chart this is in the Studies8.cpp file. Here are instructions to modify the source code: http://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-13 21:07:34] |
Thanks, I've never coded in my life though : ) That's why I said I'd pay to have it coded right (imo). I don't use the entire range but the real body for WRB analysis. I'll take a look and see if I can figure it out though... Sierra Chart is the best platform hands down, thanks! |
[2015-07-16 03:29:01] |
We will modify the study with an input to do what you need. It will have: Use Open to Close Range Only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-16 03:43:29] |
Great, thanks very much. It's fine and prefered if it still paints the wick the same color as the body, the way the study is now. Whatever's easier for you though, I know your busy!
