Date/Time: Sat, 21 Dec 2024 18:25:18 +0000
Secondary scale
View Count: 809
[2015-07-09 10:12:02] |
User58159 - Posts: 62 |
Dear SC, I use main NQ chart with scale on my right hand side. In that main graph you can see secondary chart, the difference between ask volume and bid volume chart. Both graphs have independent scales. I want to see the secondary scale (the diffrence) on my left hand side. Is it possible? So, I kindly ask you to advice See enclosure. Date Time Of Last Edit: 2015-07-09 10:12:36
Secondary scale.jpg / V - Attached On 2015-07-09 10:10:32 UTC - Size: 144.59 KB - 341 views |
[2015-07-09 17:31:11] |
You need to enable the option "Use Left Side Scale" in Chart Settings: http://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#UseLeftSideScale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-09 17:31:27
[2015-07-09 18:36:38] |
The problem is different. I wish to see both scales, one on the right (NQ graph) and the second on the left side (ask/bid volume difference .. Please, advice .. PS: I am studying your http:// ... |
[2015-07-09 18:40:20] |
We are not understanding this. Did you enable the option Use Left Side Scale?
[2015-07-09 18:41:49] |
I am checking it. Please, wait ..
[2015-07-09 18:43:09] |
Yes, it works, I thak you ..
