Date/Time: Sat, 21 Dec 2024 18:28:32 +0000
candle difference on volume bar chart and 60 minutes chart on July, 8th 2015
View Count: 1413
[2015-07-08 06:34:41]
User737065 - Posts: 23
I am trading the DAX. Today I had a candle on the 100 volume chart from 10893 to 10761 at 6.39 a. m. In the 60 minutes chart there is no candle and I am also confused about the time of the candle.
Thank you for your help
[2015-07-08 07:56:04]
Check the Session Times in Chart >> Chart Settings to make sure they cover the full 24 hours.
Post an image of the 60 minute cchart, sochar..t so we can have a better understanding. Here are instructions:
Also what is the time zone set to in Sierra Chart?
[2015-07-08 08:23:35]
I have posted an image of the 60 minute chart as well as an image of the 100 volume chart, where the candle is visible.
The time zone is Brussels.
Thank you, regards
[2015-07-08 10:28:55]
We do not see any charts posted here. Here are instructions:
[2015-07-08 11:16:40]
here I could insert a link:
60 minutes chart
http://www.sierrachart.com/image.php?l=1436354027235.png
1000 volume bar chart
http://www.sierrachart.com/image.php?l=1436354171210.png
[2015-07-08 17:36:41]
It is hard to make a comparison between these two charts because the bar durations are different and variable for the volume bars.
To make them similar to each other, go to the 60 minute chart, select Chart >> Chart Settings >> Advanced Settings. Set the Continuous Contract option to be the same as the volume chart. You are using Continuous Futures Contract -Volume Based Rollover.
Go to the volume chart and select Chart >> Chart Settings. Enable New Bar at Session Start.
Also to make sure you are clear about what futures contract month you are looking at, enable Chart >> Show Rollover Dates for both charts.
[2015-07-09 04:56:28]
Thank your for your assistance, my issue is solved.
Best regards
