Date/Time: Sat, 21 Dec 2024 18:38:30 +0000
Some Forex Issues wit SC data feed (1st and 2nd Instance of SC)
View Count: 873
[2015-07-03 15:48:59] |
User39772 - Posts: 311 |
1st Instance SC = connected to broker 2nd Instance SC = SC Forex Feed I load Forex data in 1st Instance and see Chart [R]. 1st Issue: When I send an order via chart to IB i get the message: Unknown Symbol with ID 364 (EURUSD). I know that this was no problem with an older SC version. 2nd Issue: No historical charts for EURAUD, EURNOK but historical charts for EURUSD and EURJPY. 3rd Issue: I there any volume data available ? |
[2015-07-03 16:47:44] |
Remark: The daily EURUSD chart does not show up to date data it shows data only until 2013. |
[2015-07-04 20:28:36] |
1. Follow step 10 here: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#Sharing 2. See answer at the end of this response. 3. Not with Forex symbols. The daily EURUSD chart does not show up to date data it shows data only until 2013. http://www.sierrachart.com/index.php?page=doc/helpdetails6.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-04 20:29:18
[2015-07-05 09:47:21] |
1. Follow step 10 here: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#Sharing I understood that I have to manually insert the IB syntax into field "Trade and current Quote Symbol" e.g. EUR.USD-CASH-IDEALPRO so that an order can be sent to TWS while using SC Forex feed on EURUSD. This is very cumbersome for someone who actively trades several forex pairs and switches between the pairs regularyly. As a programmer myself I understand that you have to find a way to match the TWS syntax. But what I do not understand is why the syntax is not strored once entered with a reference (pointer) to the corresponding SC feed symbol, so that one do not have to enter it everytime I chance the symbol. Example for such a table: SC-Symbol TWS-Symbol EURUSD EUR.USD-CASH-IDEALPRO EURCAD EUR.CAD-CASH-IDEALPRO EURJPY EUR.JPY-CASH-IDEALPRO Implemented as a reference table that is loaded when SC starts. Just a suggestion to make life easier for the user :-) .... |
[2015-07-06 07:33:36] |
What we need to do is add a new Symbol Setting for the Trade and Current Quote Symbol. We will do that. It will be found in Global Settings >> Symbol Settings.
[2015-07-09 19:37:01] |
Hello, at the moment I do not see a change since it is still not possible to send orders to TWS. Is this already done or do I have to take sth. into account or change sth. here ? |
[2015-07-09 21:06:41] |
The new symbol setting mentioned in post #5 has not yet been done. However, that is not going to prevent you from manually setting the Trade and Current Quote Symbol in a chart.
[2015-07-14 18:43:42] |
Thank you. I really appreciate how you care about your customers needs. |
