Date/Time: Sat, 21 Dec 2024 18:27:13 +0000
USD-x data previous to 2010
View Count: 847
[2015-07-03 07:54:25] |
User34124 - Posts: 279 |
Hi is there any way this can go back to 2007, as it is based off the FX feed's data anyway?
[2015-07-03 12:49:53] |
Do you need historical Daily data or Intraday data?
[2015-07-03 21:02:21] |
INtraday preferably
[2015-07-05 00:02:07] |
We will add data back to 2008-05-04 for this symbol. This is all that is available.
[2015-07-15 11:38:47] |
We have not extended the data for this yet and we will do it over the weekend. We do not want to do this operation when the index is being calculated.
