Date/Time: Sat, 21 Dec 2024 18:29:02 +0000
show dominate diagonal volume on Number Bars
View Count: 800
[2015-07-01 17:04:42] |
User84364 - Posts: 10 |
I'm currently using Number Bars to highlight the dominate diagonal volume. The highlight is a nice feature, but is there a way to show the actual volume (or bid- ask) for the diagonal calculations?
[2015-07-01 17:59:49] |
No. This is not supported.
[2015-07-28 02:40:38] |
User438740 - Posts: 2 |
well well there be an update to this feature in the future?
