Date/Time: Sat, 23 Nov 2024 06:55:26 +0000
connection issues
View Count: 2152
[2013-06-03 13:46:02]
M5amhan - Posts: 468
i posted here a week or so ago about the 30 year bonds data not coming in.. well im still having that problem but it is happening to random instruments. right now the soybeans arent working, sometimes its the dollar. i have to disconnect and reconnect all the time and sometimes one of them doesnt end up working. say for instance the bonds arent working, i dis & reconnect then the bonds will come back on but the dollar stops working.
could you please look into this?
edit: this never happened before GSP server in case that helps
Date Time Of Last Edit: 2013-06-03 13:46:57
imageZS.PNG / V - Attached On 2013-06-03 13:45:59 UTC - Size: 21.37 KB - 541 views
[2013-06-03 16:03:09]
Please post a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2013-06-03 16:10:59]
there is a ton of rows here because i use the quoteboard
i can restart and post that log if it would be easier for you
Software version: 982 | 2013-06-03 08:10:55
Current Service Package: 3 | 2013-06-03 08:10:55
Sierra Chart Historical Data Service is included. | 2013-06-03 08:10:55
Active service: TransAct | 2013-06-03 08:10:55
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-06-03 08:10:55
2013-06-03 08:10:55 Local computer clock time | 2013-06-03 08:10:55
2013-06-03 13:10:55 GMT time | 2013-06-03 08:10:55
2013-06-03 08:10:55 Time zone adjusted time | 2013-06-03 08:10:55
Time difference to server time: 1 seconds. | 2013-06-03 08:10:55
Program path: C:\SierraChart\SierraChartTransActMA\ | 2013-06-03 08:10:55
Data Files path: C:\SierraChart\Data\ | 2013-06-03 08:10:55
OS Version Number: 5.1 | 2013-06-03 08:10:55
Chartbook file not found: C:\SierraChart\Data\Infinity Chart Startup.cht | 2013-06-03 08:10:57
Limiting the number of days back for the continuous futures chart to 3 years based on the account type. | 2013-06-03 08:10:59
Symbols used for GCM13 continuous contract chart: | 2013-06-03 08:10:59
GCM10 | 2013-06-03 08:10:59
GCQ10 | 2013-06-03 08:10:59
GCZ10 | 2013-06-03 08:10:59
GCG11 | 2013-06-03 08:10:59
GCJ11 | 2013-06-03 08:10:59
GCM11 | 2013-06-03 08:10:59
GCQ11 | 2013-06-03 08:10:59
GCZ11 | 2013-06-03 08:10:59
GCG12 | 2013-06-03 08:10:59
GCJ12 | 2013-06-03 08:10:59
GCM12 | 2013-06-03 08:10:59
GCQ12 | 2013-06-03 08:10:59
GCZ12 | 2013-06-03 08:10:59
GCG13 | 2013-06-03 08:10:59
GCJ13 | 2013-06-03 08:10:59
GCM13 | 2013-06-03 08:10:59
Symbols used for DXM13 continuous contract chart: | 2013-06-03 08:10:59
DXM10 | 2013-06-03 08:10:59
DXU10 | 2013-06-03 08:10:59
DXZ10 | 2013-06-03 08:10:59
DXH11 | 2013-06-03 08:10:59
DXM11 | 2013-06-03 08:10:59
DXU11 | 2013-06-03 08:10:59
DXZ11 | 2013-06-03 08:10:59
DXH12 | 2013-06-03 08:10:59
DXM12 | 2013-06-03 08:10:59
DXU12 | 2013-06-03 08:10:59
DXZ12 | 2013-06-03 08:10:59
DXH13 | 2013-06-03 08:10:59
DXM13 | 2013-06-03 08:10:59
Symbols used for ESM13 continuous contract chart: | 2013-06-03 08:10:59
ESM10 | 2013-06-03 08:10:59
ESU10 | 2013-06-03 08:10:59
ESZ10 | 2013-06-03 08:10:59
ESH11 | 2013-06-03 08:10:59
ESM11 | 2013-06-03 08:10:59
ESU11 | 2013-06-03 08:10:59
ESZ11 | 2013-06-03 08:10:59
ESH12 | 2013-06-03 08:10:59
ESM12 | 2013-06-03 08:10:59
ESU12 | 2013-06-03 08:10:59
ESZ12 | 2013-06-03 08:10:59
ESH13 | 2013-06-03 08:10:59
ESM13 | 2013-06-03 08:10:59
Unable to determine the symbols and settings necessary to load $DOWT.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-06-03 08:10:59
Limiting the number of days back for the continuous futures chart to 3 years based on the account type. | 2013-06-03 08:11:02
Symbols used for GCQ13 continuous contract chart: | 2013-06-03 08:11:02
GCZ11 | 2013-06-03 08:11:02
GCG12 | 2013-06-03 08:11:02
GCJ12 | 2013-06-03 08:11:02
GCM12 | 2013-06-03 08:11:02
GCQ12 | 2013-06-03 08:11:02
GCZ12 | 2013-06-03 08:11:02
GCG13 | 2013-06-03 08:11:02
GCJ13 | 2013-06-03 08:11:02
GCM13 | 2013-06-03 08:11:02
GCQ13 | 2013-06-03 08:11:02
Chart #5 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:02
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:02
Chart #4 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:02
HD Request # 1 - Downloading Intraday chart data for CLN3 to the file CLN3.scid. Service: scsrv | 2013-06-03 08:11:02
HD Request # 1 - Starting date and time: 2013-06-03 00:37:04 | 2013-06-03 08:11:02
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:02
HD Request # 1 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 08:11:02
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:02
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:02
The network socket is connected. | 2013-06-03 08:11:02
HD Request # 1 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:02
HD Request # 3 - Downloading Historical Daily chart data for $DOWT. Starting date: 2013-05-30. Service: ddf | 2013-06-03 08:11:03
HD Request # 3 - Requesting historical Daily data for $DOWT starting at 2013-05-29 | 2013-06-03 08:11:03
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 08:11:03
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 08:11:03
HD Request # 1 - Decompressing data. | 2013-06-03 08:11:03
Socket closed. No error. | 2013-06-03 08:11:03
HD Request # 1 - Historical data for CLN3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 08:11:03
HD Request # 1 - Received 0 records and wrote 0 records for CLN3 | 2013-06-03 08:11:03
HD Request # 1 - Intraday download COMPLETE for CLN3 | 2013-06-03 08:11:03
HD Request # 4 - Downloading Intraday chart data for TFM3 to the file TFM3.scid. Service: scsrv | 2013-06-03 08:11:03
HD Request # 4 - Starting date and time: 2013-06-03 00:36:11 | 2013-06-03 08:11:03
HD Request # 4 - Using server: ds4.sierracharts.com port 10049 | 2013-06-03 08:11:03
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:03
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:03
HD Request # 3 - Receiving historical Daily data for $DOWT starting at 2013-05-29 | 2013-06-03 08:11:03
Writing historical daily data for $DOWT to the file $DOWT.dly | 2013-06-03 08:11:03
Unable to determine the symbols and settings necessary to load $DOWT.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-06-03 08:11:03
Chart #9 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:03
HD Request # 3 - Received 3 records from 2013-05-29 00:00:00 to 2013-05-31 00:00:00 (3.0 days) and wrote 2 records for $DOWT | 2013-06-03 08:11:03
HD Request # 3 - Daily download COMPLETE for $DOWT | 2013-06-03 08:11:03
HD Request # 6 - Downloading Historical Daily chart data for ZS#. Starting date: 2013-05-31. Service: ddf | 2013-06-03 08:11:03
HD Request # 6 - Requesting historical Daily Continuous data for ZSZ10 starting at 2013-05-30 | 2013-06-03 08:11:03
HD Request # 6 - Receiving historical Daily data for ZS# starting at 2013-05-30 | 2013-06-03 08:11:03
Writing historical daily data for ZS# to the file ZS#.dly | 2013-06-03 08:11:03
The network socket is connected. | 2013-06-03 08:11:03
HD Request # 4 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:03
HD Request # 4 - Decompressing data. | 2013-06-03 08:11:04
Socket closed. No error. | 2013-06-03 08:11:04
Chart #1 has tagged chart #2 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 08:11:04
Chart #1 has tagged chart #3 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 08:11:04
HD Request # 6 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for ZS# | 2013-06-03 08:11:06
HD Request # 6 - Daily download COMPLETE for ZS# | 2013-06-03 08:11:06
HD Request # 4 - Historical data for TFM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 08:11:06
HD Request # 4 - Received 0 records and wrote 0 records for TFM3 | 2013-06-03 08:11:06
HD Request # 4 - Intraday download COMPLETE for TFM3 | 2013-06-03 08:11:06
HD Request # 7 - Downloading Intraday chart data for ESM3 to the file ESM3.scid. Service: scsrv | 2013-06-03 08:11:06
HD Request # 7 - Starting date and time: 2013-06-03 00:36:54 | 2013-06-03 08:11:06
HD Request # 7 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 08:11:06
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 08:11:06
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:06
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:06
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:06
Chart #1 has tagged chart #2 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 08:11:06
Chart #1 has tagged chart #3 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 08:11:06
The network socket is connected. | 2013-06-03 08:11:06
HD Request # 7 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:06
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 08:11:06
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: SwingCharts.cht | 2013-06-03 08:11:06
HD Request # 7 - Decompressing data. | 2013-06-03 08:11:06
Socket closed. No error. | 2013-06-03 08:11:06
HD Request # 7 - Historical data for ESM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 08:11:06
HD Request # 7 - Received 0 records and wrote 0 records for ESM3 | 2013-06-03 08:11:06
HD Request # 7 - Intraday download COMPLETE for ESM3 | 2013-06-03 08:11:06
HD Request # 9 - Downloading Intraday chart data for NQM3 to the file NQM3.scid. Service: scsrv | 2013-06-03 08:11:06
HD Request # 9 - Starting date and time: 2013-06-03 00:36:56 | 2013-06-03 08:11:06
HD Request # 9 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 08:11:06
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:06
GSP - Port for executable: 17858 | 2013-06-03 08:11:06
GSP - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-06-03 08:11:06
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: SwingCharts.cht | 2013-06-03 08:11:06
HD Request # 9 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:06
HD Request # 9 - Decompressing data. | 2013-06-03 08:11:07
Socket closed. No error. | 2013-06-03 08:11:07
HD Request # 9 - Historical data for NQM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 08:11:07
HD Request # 9 - Received 0 records and wrote 0 records for NQM3 | 2013-06-03 08:11:07
HD Request # 9 - Intraday download COMPLETE for NQM3 | 2013-06-03 08:11:07
HD Request # 11 - Downloading Intraday chart data for YMM3 to the file YMM3.scid. Service: scsrv | 2013-06-03 08:11:07
HD Request # 11 - Starting date and time: 2013-06-03 00:36:40 | 2013-06-03 08:11:07
HD Request # 11 - Using server: ds4.sierracharts.com port 10049 | 2013-06-03 08:11:07
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 08:11:07
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:07
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:07
The network socket is connected. | 2013-06-03 08:11:07
HD Request # 11 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:07
Chart #4 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:07
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:07
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 08:11:07
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:08
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:08
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 08:11:08
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 08:11:08
HD Request # 11 - Decompressing data. | 2013-06-03 08:11:08
Socket closed. No error. | 2013-06-03 08:11:08
HD Request # 11 - Historical data for YMM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 08:11:08
HD Request # 11 - Received 0 records and wrote 0 records for YMM3 | 2013-06-03 08:11:08
HD Request # 11 - Intraday download COMPLETE for YMM3 | 2013-06-03 08:11:08
HD Request # 13 - Downloading Intraday chart data for GCQ3 to the file GCQ3.scid. Service: scsrv | 2013-06-03 08:11:08
HD Request # 13 - Starting date and time: 2013-06-03 00:36:57 | 2013-06-03 08:11:08
HD Request # 13 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 08:11:08
The network socket is connected. | 2013-06-03 08:11:08
HD Request # 13 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:08
HD Request # 15 - Downloading Historical Daily chart data for GCM13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 08:11:08
HD Request # 15 - Requesting historical Daily data for GCM13 starting at 2013-05-30 | 2013-06-03 08:11:08
Chart #5 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:08
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:08
HD Request # 15 - Receiving historical Daily data for GCM13 starting at 2013-05-30 | 2013-06-03 08:11:08
Writing historical daily data for GCM13 to the file GCM13.dly | 2013-06-03 08:11:08
HD Request # 15 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for GCM13 | 2013-06-03 08:11:08
HD Request # 15 - Daily download COMPLETE for GCM13 | 2013-06-03 08:11:08
HD Request # 16 - Downloading Historical Daily chart data for DXH13. Starting date: 2013-03-15. Service: ddf | 2013-06-03 08:11:08
HD Request # 16 - Requesting historical Daily data for DXH13 starting at 2013-03-14 | 2013-06-03 08:11:08
HD Request # 16 - Receiving historical Daily data for DXH13 starting at 2013-03-14 | 2013-06-03 08:11:08
Writing historical daily data for DXH13 to the file DXH13.dly | 2013-06-03 08:11:08
HD Request # 16 - Received 3 records from 2013-03-14 00:00:00 to 2013-03-18 00:00:00 (5.0 days) and wrote 2 records for DXH13 | 2013-06-03 08:11:08
HD Request # 16 - Daily download COMPLETE for DXH13 | 2013-06-03 08:11:08
HD Request # 17 - Downloading Historical Daily chart data for GCQ13. Starting date: 2013-05-30. Service: ddf | 2013-06-03 08:11:08
HD Request # 17 - Requesting historical Daily data for GCQ13 starting at 2013-05-29 | 2013-06-03 08:11:08
HD Request # 13 - Decompressing data. | 2013-06-03 08:11:08
HD Request # 13 - Historical data for GCQ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 08:11:08
HD Request # 13 - Received 0 records and wrote 0 records for GCQ3 | 2013-06-03 08:11:08
HD Request # 13 - Intraday download COMPLETE for GCQ3 | 2013-06-03 08:11:08
HD Request # 17 - Receiving historical Daily data for GCQ13 starting at 2013-05-29 | 2013-06-03 08:11:08
Writing historical daily data for GCQ13 to the file GCQ13.dly | 2013-06-03 08:11:08
HD Request # 17 - Received 4 records from 2013-05-29 00:00:00 to 2013-06-03 00:00:00 (6.0 days) and wrote 3 records for GCQ13 | 2013-06-03 08:11:08
HD Request # 17 - Daily download COMPLETE for GCQ13 | 2013-06-03 08:11:08
HD Request # 18 - Downloading Historical Daily chart data for ESH13. Starting date: 2013-03-14. Service: ddf | 2013-06-03 08:11:08
HD Request # 18 - Requesting historical Daily data for ESH13 starting at 2013-03-13 | 2013-06-03 08:11:08
GSP: Connecting to the server localhost. Port 17858 | 2013-06-03 08:11:08
LoadContinuousDailyData: Using GCZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:08
LoadContinuousDailyData: Transitioning from GCZ11 (2011-11-29 V:64786) to GCG12 (2011-11-29 V:158257). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCG12. Earliest transition date: 2012-01-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCG12 (2012-01-30 V:53427) to GCJ12 (2012-01-30 V:133373). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCJ12. Earliest transition date: 2012-03-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCJ12 (2012-03-29 V:47342) to GCM12 (2012-03-29 V:163878). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCM12. Earliest transition date: 2012-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCM12 (2012-05-30 V:79887) to GCQ12 (2012-05-30 V:273695). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCQ12. Earliest transition date: 2012-07-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCQ12 (2012-07-30 V:52890) to GCZ12 (2012-07-30 V:111653). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCZ12. Earliest transition date: 2012-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCZ12 (2012-11-29 V:65599) to GCG13 (2012-11-29 V:178274). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCG13. Earliest transition date: 2013-01-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCG13 (2013-01-30 V:44893) to GCJ13 (2013-01-30 V:183223). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCJ13. Earliest transition date: 2013-03-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCJ13 (2013-03-27 V:50450) to GCM13 (2013-03-27 V:179889). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCM13. Earliest transition date: 2013-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCM13 (2013-05-30 V:45133) to GCQ13 (2013-05-30 V:202829). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCQ13. Earliest transition date: 2013-07-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Reached the end of GCQ13 at 2013-06-03. This is the last symbol. | 2013-06-03 08:11:09
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 08:11:09
The network socket is connected. | 2013-06-03 08:11:09
GSP: Connected to server. Waiting to send data. | 2013-06-03 08:11:09
GSP Server Info - Server Name: TransactToSierraBridge . Server Version: 1.1.5 . Provider Name: Transact Futures . | 2013-06-03 08:11:09
GSP - Server protocol version: 1. Client protocol version: 1. There is a protocol match. | 2013-06-03 08:11:09
Transact Futures: Sending logon request. | 2013-06-03 08:11:09
HD Request # 18 - Receiving historical Daily data for ESH13 starting at 2013-03-13 | 2013-06-03 08:11:09
Writing historical daily data for ESH13 to the file ESH13.dly | 2013-06-03 08:11:09
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:09
HD Request # 18 - Received 3 records from 2013-03-13 00:00:00 to 2013-03-15 00:00:00 (3.0 days) and wrote 2 records for ESH13 | 2013-06-03 08:11:09
HD Request # 18 - Daily download COMPLETE for ESH13 | 2013-06-03 08:11:09
HD Request # 19 - Downloading Historical Daily chart data for DXM13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 08:11:09
HD Request # 19 - Requesting historical Daily data for DXM13 starting at 2013-05-30 | 2013-06-03 08:11:09
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 08:11:09
Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:09
HD Request # 19 - Receiving historical Daily data for DXM13 starting at 2013-05-30 | 2013-06-03 08:11:09
Writing historical daily data for DXM13 to the file DXM13.dly | 2013-06-03 08:11:09
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:09
HD Request # 19 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for DXM13 | 2013-06-03 08:11:09
HD Request # 19 - Daily download COMPLETE for DXM13 | 2013-06-03 08:11:09
HD Request # 20 - Downloading Historical Daily chart data for GCJ13. Starting date: 2013-04-25. Service: ddf | 2013-06-03 08:11:09
HD Request # 20 - Requesting historical Daily data for GCJ13 starting at 2013-04-24 | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXM10. Earliest transition date: 2010-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXM10 (2010-06-11 V:14703) to DXU10 (2010-06-11 V:34418). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXU10. Earliest transition date: 2010-08-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXU10 (2010-09-10 V:10084) to DXZ10 (2010-09-10 V:19814). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXZ10. Earliest transition date: 2010-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXZ10 (2010-12-10 V:10233) to DXH11 (2010-12-10 V:18914). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXH11. Earliest transition date: 2011-02-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXH11 (2011-03-11 V:14943) to DXM11 (2011-03-11 V:29038). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXM11. Earliest transition date: 2011-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXM11 (2011-06-10 V:19307) to DXU11 (2011-06-10 V:36301). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXU11. Earliest transition date: 2011-08-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXU11 (2011-09-15 V:27356) to DXZ11 (2011-09-15 V:44044). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXZ11 (2011-12-15 V:22853) to DXH12 (2011-12-15 V:25983). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXH12. Earliest transition date: 2012-02-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXH12 (2012-03-14 V:38980) to DXM12 (2012-03-14 V:42141). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXM12. Earliest transition date: 2012-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXM12 (2012-06-15 V:12983) to DXU12 (2012-06-15 V:28352). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXU12. Earliest transition date: 2012-08-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXU12 (2012-09-14 V:16153) to DXZ12 (2012-09-14 V:36450). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXZ12. Earliest transition date: 2012-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXZ12 (2012-12-13 V:19357) to DXH13 (2012-12-13 V:20619). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXH13. Earliest transition date: 2013-02-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from DXH13 (2013-03-14 V:36804) to DXM13 (2013-03-14 V:49631). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using DXM13. Earliest transition date: 2013-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Reached the end of DXM13 at 2013-06-03. This is the last symbol. | 2013-06-03 08:11:09
HD Request # 20 - Receiving historical Daily data for GCJ13 starting at 2013-04-24 | 2013-06-03 08:11:09
Writing historical daily data for GCJ13 to the file GCJ13.dly | 2013-06-03 08:11:09
HD Request # 20 - Received 3 records from 2013-04-24 00:00:00 to 2013-04-26 00:00:00 (3.0 days) and wrote 2 records for GCJ13 | 2013-06-03 08:11:09
HD Request # 20 - Daily download COMPLETE for GCJ13 | 2013-06-03 08:11:09
HD Request # 21 - Downloading Historical Daily chart data for ESM13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 08:11:09
HD Request # 21 - Requesting historical Daily data for ESM13 starting at 2013-05-30 | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCM10. Earliest transition date: 2010-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCM10 (2010-05-27 V:109434) to GCQ10 (2010-05-27 V:138265). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCQ10. Earliest transition date: 2010-07-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCQ10 (2010-07-29 V:54384) to GCZ10 (2010-07-29 V:113129). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCZ10. Earliest transition date: 2010-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCZ10 (2010-11-29 V:94486) to GCG11 (2010-11-29 V:184840). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCG11. Earliest transition date: 2011-01-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCG11 (2011-01-28 V:73023) to GCJ11 (2011-01-28 V:251014). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCJ11. Earliest transition date: 2011-03-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCJ11 (2011-03-29 V:135792) to GCM11 (2011-03-29 V:140893). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCM11. Earliest transition date: 2011-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCM11 (2011-05-27 V:76719) to GCQ11 (2011-05-27 V:138115). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCQ11. Earliest transition date: 2011-07-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from GCQ11 (2011-07-28 V:70263) to GCZ11 (2011-07-28 V:163995). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using GCZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Reached the end of GCM13 at 2013-06-03. This is the last symbol. | 2013-06-03 08:11:09
HD Request # 21 - Receiving historical Daily data for ESM13 starting at 2013-05-30 | 2013-06-03 08:11:09
Writing historical daily data for ESM13 to the file ESM13.dly | 2013-06-03 08:11:09
HD Request # 21 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for ESM13 | 2013-06-03 08:11:09
HD Request # 21 - Daily download COMPLETE for ESM13 | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESM10. Earliest transition date: 2010-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESM10 (2010-06-11 V:1182031) to ESU10 (2010-06-11 V:2234724). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESU10. Earliest transition date: 2010-08-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESU10 (2010-09-10 V:892734) to ESZ10 (2010-09-10 V:1530259). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESZ10. Earliest transition date: 2010-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESZ10 (2010-12-10 V:893224) to ESH11 (2010-12-10 V:1450096). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESH11. Earliest transition date: 2011-02-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESH11 (2011-03-11 V:1125367) to ESM11 (2011-03-11 V:2185696). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESM11. Earliest transition date: 2011-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESM11 (2011-06-10 V:1453530) to ESU11 (2011-06-10 V:2355546). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESU11. Earliest transition date: 2011-08-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESU11 (2011-09-09 V:1615259) to ESZ11 (2011-09-09 V:3165441). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESZ11 (2011-12-09 V:1143695) to ESH12 (2011-12-09 V:2410241). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESH12. Earliest transition date: 2012-02-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESH12 (2012-03-09 V:1063406) to ESM12 (2012-03-09 V:1904083). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESM12. Earliest transition date: 2012-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESM12 (2012-06-08 V:1334158) to ESU12 (2012-06-08 V:1943155). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESU12. Earliest transition date: 2012-08-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESU12 (2012-09-14 V:1291449) to ESZ12 (2012-09-14 V:2463875). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESZ12. Earliest transition date: 2012-11-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESZ12 (2012-12-14 V:1043852) to ESH13 (2012-12-14 V:1689033). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESH13. Earliest transition date: 2013-02-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Transitioning from ESH13 (2013-03-08 V:1136905) to ESM13 (2013-03-08 V:1915186). | 2013-06-03 08:11:09
LoadContinuousDailyData: Using ESM13. Earliest transition date: 2013-05-01 | 2013-06-03 08:11:09
LoadContinuousDailyData: Reached the end of ESM13 at 2013-06-03. This is the last symbol. | 2013-06-03 08:11:09
Transact Futures: Successfully connected. | 2013-06-03 08:11:13
Starting updates for: GCQ3 | 2013-06-03 08:11:13
Starting updates for: CLN3 | 2013-06-03 08:11:13
HD Request # 22 - Downloading Intraday chart data for CLN3 to the file CLN3.scid. Service: scsrv | 2013-06-03 08:11:13
HD Request # 22 - Starting date and time: 2013-06-03 00:37:04 | 2013-06-03 08:11:13
Starting updates for: ESM3 | 2013-06-03 08:11:13
HD Request # 22 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 08:11:13
Starting updates for: YMM3 | 2013-06-03 08:11:13
Starting updates for: TFM3 | 2013-06-03 08:11:13
Starting updates for: NQM3 | 2013-06-03 08:11:13
Starting updates for: GCM3 | 2013-06-03 08:11:13
Starting updates for: DXM3 | 2013-06-03 08:11:13
Starting updates for: ZS# | 2013-06-03 08:11:13
Starting updates for: $DOWT | 2013-06-03 08:11:13
Symbol Error: $DOWT is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
The network socket is connected. | 2013-06-03 08:11:13
HD Request # 22 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:13
Starting updates for: RJ# | 2013-06-03 08:11:13
Starting updates for: NQ# | 2013-06-03 08:11:13
Starting updates for: YM# | 2013-06-03 08:11:13
Starting updates for: ES# | 2013-06-03 08:11:13
Starting updates for: DY# | 2013-06-03 08:11:13
Starting updates for: NY# | 2013-06-03 08:11:13
Starting updates for: ZB# | 2013-06-03 08:11:13
Starting updates for: ZN# | 2013-06-03 08:11:13
Starting updates for: ZF# | 2013-06-03 08:11:13
Starting updates for: ZT# | 2013-06-03 08:11:13
Starting updates for: UD# | 2013-06-03 08:11:13
Starting updates for: CL# | 2013-06-03 08:11:13
Starting updates for: CB# | 2013-06-03 08:11:13
Starting updates for: NG# | 2013-06-03 08:11:13
Starting updates for: RB# | 2013-06-03 08:11:13
Starting updates for: GC# | 2013-06-03 08:11:13
Starting updates for: SI# | 2013-06-03 08:11:13
Starting updates for: PL# | 2013-06-03 08:11:13
Starting updates for: HG# | 2013-06-03 08:11:13
Starting updates for: DX# | 2013-06-03 08:11:13
Starting updates for: A6# | 2013-06-03 08:11:13
Starting updates for: B6# | 2013-06-03 08:11:13
Starting updates for: D6# | 2013-06-03 08:11:13
Starting updates for: E6# | 2013-06-03 08:11:13
Starting updates for: J6# | 2013-06-03 08:11:13
Starting updates for: N6# | 2013-06-03 08:11:13
Starting updates for: S6# | 2013-06-03 08:11:13
Starting updates for: KC# | 2013-06-03 08:11:13
Starting updates for: CT# | 2013-06-03 08:11:13
Starting updates for: CC# | 2013-06-03 08:11:13
Starting updates for: SB# | 2013-06-03 08:11:13
Starting updates for: LE# | 2013-06-03 08:11:13
Starting updates for: HE# | 2013-06-03 08:11:13
Starting updates for: ZC# | 2013-06-03 08:11:13
Starting updates for: ZW# | 2013-06-03 08:11:13
Starting updates for: ZL# | 2013-06-03 08:11:13
Starting updates for: ZM# | 2013-06-03 08:11:13
Symbol Error: RJ# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: DY# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: NY# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: ZF# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: ZT# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: UD# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: CB# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: RB# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: SI# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: PL# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: HG# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: A6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: B6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: D6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: E6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: J6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: N6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: S6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: KC# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: CT# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: CC# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: SB# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: LE# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: HE# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: ZL# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Symbol Error: ZM# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 08:11:13
Starting updates for: FDAXM3 | 2013-06-03 08:11:13
Starting updates for: ZBU3 | 2013-06-03 08:11:13
Starting updates for: ZSN3 | 2013-06-03 08:11:13
Starting updates for: 6EM3 | 2013-06-03 08:11:13
Starting updates for: 6BM3 | 2013-06-03 08:11:13
Starting updates for: 6JM3 | 2013-06-03 08:11:13
Starting updates for: $NSHF | 2013-06-03 08:11:13
SC Market Stats: Connecting to the market data server. | 2013-06-03 08:11:13
Using server: ds4.sierracharts.com, port 443 | 2013-06-03 08:11:13
SC Market Stats - Local market data port: 0 | 2013-06-03 08:11:13
SC Market Stats: Connected to market data server. Now authorizing. | 2013-06-03 08:11:13
HD Request # 22 - Decompressing data. | 2013-06-03 08:11:13
HD Request # 22 - Receiving Intraday data for CLN3 starting at 2013-06-03 00:37:07 | 2013-06-03 08:11:13
HD Request # 22 - Timestamp of first Intraday data file record written: 2013-06-03 00:37:07 | 2013-06-03 08:11:13
SC Market Stats server: Connected. Subscribing to symbols. | 2013-06-03 08:11:13
Restarting real-time data updates for symbol: $NSHF | 2013-06-03 08:11:13
LoadContinuousDailyData: Using GCZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCZ11 (2011-11-29 V:64786) to GCG12 (2011-11-29 V:158257). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCG12. Earliest transition date: 2012-01-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCG12 (2012-01-30 V:53427) to GCJ12 (2012-01-30 V:133373). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCJ12. Earliest transition date: 2012-03-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCJ12 (2012-03-29 V:47342) to GCM12 (2012-03-29 V:163878). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCM12. Earliest transition date: 2012-05-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCM12 (2012-05-30 V:79887) to GCQ12 (2012-05-30 V:273695). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCQ12. Earliest transition date: 2012-07-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCQ12 (2012-07-30 V:52890) to GCZ12 (2012-07-30 V:111653). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCZ12. Earliest transition date: 2012-11-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCZ12 (2012-11-29 V:65599) to GCG13 (2012-11-29 V:178274). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCG13. Earliest transition date: 2013-01-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCG13 (2013-01-30 V:44893) to GCJ13 (2013-01-30 V:183223). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCJ13. Earliest transition date: 2013-03-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCJ13 (2013-03-27 V:50450) to GCM13 (2013-03-27 V:179889). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCM13. Earliest transition date: 2013-05-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Transitioning from GCM13 (2013-05-30 V:45133) to GCQ13 (2013-05-30 V:202829). | 2013-06-03 08:11:14
LoadContinuousDailyData: Using GCQ13. Earliest transition date: 2013-07-01 | 2013-06-03 08:11:14
LoadContinuousDailyData: Reached the end of GCQ13 at 2013-06-03. This is the last symbol. | 2013-06-03 08:11:14
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 08:11:14
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 08:11:14
Socket closed. No error. | 2013-06-03 08:11:15
HD Request # 22 - Received 27236 records from 2013-06-03 00:37:07 to 2013-06-03 08:11:14 (7.6 hours) and wrote 27236 records for CLN3 | 2013-06-03 08:11:15
HD Request # 22 - Intraday download COMPLETE for CLN3 | 2013-06-03 08:11:15
Real-time intraday chart data file updates started for CLN3 | 2013-06-03 08:11:15
HD Request # 24 - Downloading Intraday chart data for ESM3 to the file ESM3.scid. Service: scsrv | 2013-06-03 08:11:15
HD Request # 24 - Starting date and time: 2013-06-03 00:36:54 | 2013-06-03 08:11:15
HD Request # 24 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 08:11:15
The network socket is connected. | 2013-06-03 08:11:15
HD Request # 24 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:15
HD Request # 24 - Decompressing data. | 2013-06-03 08:11:16
HD Request # 24 - Receiving Intraday data for ESM3 starting at 2013-06-03 00:36:57 | 2013-06-03 08:11:16
HD Request # 24 - Timestamp of first Intraday data file record written: 2013-06-03 00:36:57 | 2013-06-03 08:11:16
Transact Futures: Requesting Trade positions data. | 2013-06-03 08:11:18
Socket closed. No error. | 2013-06-03 08:11:19
HD Request # 24 - Received 80772 records from 2013-06-03 00:36:57 to 2013-06-03 08:11:16 (7.6 hours) and wrote 80772 records for ESM3 | 2013-06-03 08:11:19
HD Request # 24 - Intraday download COMPLETE for ESM3 | 2013-06-03 08:11:19
Real-time intraday chart data file updates started for ESM3 | 2013-06-03 08:11:19
HD Request # 26 - Downloading Intraday chart data for YMM3 to the file YMM3.scid. Service: scsrv | 2013-06-03 08:11:19
HD Request # 26 - Starting date and time: 2013-06-03 00:36:40 | 2013-06-03 08:11:19
HD Request # 26 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 08:11:19
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:19
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:19
The network socket is connected. | 2013-06-03 08:11:19
HD Request # 26 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:19
HD Request # 26 - Decompressing data. | 2013-06-03 08:11:20
HD Request # 26 - Receiving Intraday data for YMM3 starting at 2013-06-03 00:36:43 | 2013-06-03 08:11:20
HD Request # 26 - Timestamp of first Intraday data file record written: 2013-06-03 00:36:43 | 2013-06-03 08:11:20
Socket closed. No error. | 2013-06-03 08:11:20
HD Request # 26 - Received 18584 records from 2013-06-03 00:36:43 to 2013-06-03 08:11:15 (7.6 hours) and wrote 18584 records for YMM3 | 2013-06-03 08:11:20
HD Request # 26 - Intraday download COMPLETE for YMM3 | 2013-06-03 08:11:20
Real-time intraday chart data file updates started for YMM3 | 2013-06-03 08:11:20
HD Request # 28 - Downloading Intraday chart data for GCQ3 to the file GCQ3.scid. Service: scsrv | 2013-06-03 08:11:20
HD Request # 28 - Starting date and time: 2013-06-03 00:36:57 | 2013-06-03 08:11:20
HD Request # 28 - Using server: ds4.sierracharts.com port 10049 | 2013-06-03 08:11:20
Chart #5 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:20
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:20
The network socket is connected. | 2013-06-03 08:11:20
HD Request # 28 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:20
LoadContinuousDailyData: Using ESM10. Earliest transition date: 2010-05-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESM10 (2010-06-11 V:1182031) to ESU10 (2010-06-11 V:2234724). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESU10. Earliest transition date: 2010-08-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESU10 (2010-09-10 V:892734) to ESZ10 (2010-09-10 V:1530259). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESZ10. Earliest transition date: 2010-11-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESZ10 (2010-12-10 V:893224) to ESH11 (2010-12-10 V:1450096). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESH11. Earliest transition date: 2011-02-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESH11 (2011-03-11 V:1125367) to ESM11 (2011-03-11 V:2185696). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESM11. Earliest transition date: 2011-05-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESM11 (2011-06-10 V:1453530) to ESU11 (2011-06-10 V:2355546). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESU11. Earliest transition date: 2011-08-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESU11 (2011-09-09 V:1615259) to ESZ11 (2011-09-09 V:3165441). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESZ11 (2011-12-09 V:1143695) to ESH12 (2011-12-09 V:2410241). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESH12. Earliest transition date: 2012-02-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESH12 (2012-03-09 V:1063406) to ESM12 (2012-03-09 V:1904083). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESM12. Earliest transition date: 2012-05-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESM12 (2012-06-08 V:1334158) to ESU12 (2012-06-08 V:1943155). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESU12. Earliest transition date: 2012-08-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESU12 (2012-09-14 V:1291449) to ESZ12 (2012-09-14 V:2463875). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESZ12. Earliest transition date: 2012-11-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESZ12 (2012-12-14 V:1043852) to ESH13 (2012-12-14 V:1689033). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESH13. Earliest transition date: 2013-02-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Transitioning from ESH13 (2013-03-08 V:1136905) to ESM13 (2013-03-08 V:1915186). | 2013-06-03 08:11:21
LoadContinuousDailyData: Using ESM13. Earliest transition date: 2013-05-01 | 2013-06-03 08:11:21
LoadContinuousDailyData: Reached the end of ESM13 at 2013-06-03. This is the last symbol. | 2013-06-03 08:11:21
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:21
Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:21
HD Request # 28 - Decompressing data. | 2013-06-03 08:11:21
HD Request # 28 - Receiving Intraday data for GCQ3 starting at 2013-06-03 00:37:00 | 2013-06-03 08:11:21
HD Request # 28 - Timestamp of first Intraday data file record written: 2013-06-03 00:37:00 | 2013-06-03 08:11:21
Socket closed. No error. | 2013-06-03 08:11:22
HD Request # 28 - Received 22784 records from 2013-06-03 00:37:00 to 2013-06-03 08:11:20 (7.6 hours) and wrote 22784 records for GCQ3 | 2013-06-03 08:11:23
HD Request # 28 - Intraday download COMPLETE for GCQ3 | 2013-06-03 08:11:23
Real-time intraday chart data file updates started for GCQ3 | 2013-06-03 08:11:23
HD Request # 30 - Downloading Intraday chart data for TFM3 to the file TFM3.scid. Service: scsrv | 2013-06-03 08:11:23
HD Request # 30 - Starting date and time: 2013-06-03 00:36:11 | 2013-06-03 08:11:23
HD Request # 30 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 08:11:23
The network socket is connected. | 2013-06-03 08:11:23
HD Request # 30 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:23
HD Request # 30 - Decompressing data. | 2013-06-03 08:11:23
HD Request # 30 - Receiving Intraday data for TFM3 starting at 2013-06-03 00:36:14 | 2013-06-03 08:11:23
HD Request # 30 - Timestamp of first Intraday data file record written: 2013-06-03 00:36:14 | 2013-06-03 08:11:23
Socket closed. No error. | 2013-06-03 08:11:23
HD Request # 30 - Received 4967 records from 2013-06-03 00:36:14 to 2013-06-03 08:11:18 (7.6 hours) and wrote 4967 records for TFM3 | 2013-06-03 08:11:23
HD Request # 30 - Intraday download COMPLETE for TFM3 | 2013-06-03 08:11:23
Real-time intraday chart data file updates started for TFM3 | 2013-06-03 08:11:23
HD Request # 32 - Downloading Intraday chart data for NQM3 to the file NQM3.scid. Service: scsrv | 2013-06-03 08:11:23
HD Request # 32 - Starting date and time: 2013-06-03 00:36:56 | 2013-06-03 08:11:23
HD Request # 32 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 08:11:23
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:23
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:23
HD Request # 32 - Requesting up to 30 days of Intraday data. | 2013-06-03 08:11:23
HD Request # 32 - Decompressing data. | 2013-06-03 08:11:24
HD Request # 32 - Receiving Intraday data for NQM3 starting at 2013-06-03 00:36:57 | 2013-06-03 08:11:24
HD Request # 32 - Timestamp of first Intraday data file record written: 2013-06-03 00:36:57 | 2013-06-03 08:11:24
Socket closed. No error. | 2013-06-03 08:11:25
HD Request # 32 - Received 21527 records from 2013-06-03 00:36:57 to 2013-06-03 08:11:24 (7.6 hours) and wrote 21527 records for NQM3 | 2013-06-03 08:11:25
HD Request # 32 - Intraday download COMPLETE for NQM3 | 2013-06-03 08:11:25
Real-time intraday chart data file updates started for NQM3 | 2013-06-03 08:11:25
Chart #4 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 08:11:25
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 08:11:25
LoadContinuousDailyData: Using DXM10. Earliest transition date: 2010-05-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXM10 (2010-06-11 V:14703) to DXU10 (2010-06-11 V:34418). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXU10. Earliest transition date: 2010-08-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXU10 (2010-09-10 V:10084) to DXZ10 (2010-09-10 V:19814). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXZ10. Earliest transition date: 2010-11-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXZ10 (2010-12-10 V:10233) to DXH11 (2010-12-10 V:18914). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXH11. Earliest transition date: 2011-02-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXH11 (2011-03-11 V:14943) to DXM11 (2011-03-11 V:29038). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXM11. Earliest transition date: 2011-05-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXM11 (2011-06-10 V:19307) to DXU11 (2011-06-10 V:36301). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXU11. Earliest transition date: 2011-08-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXU11 (2011-09-15 V:27356) to DXZ11 (2011-09-15 V:44044). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXZ11. Earliest transition date: 2011-11-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXZ11 (2011-12-15 V:22853) to DXH12 (2011-12-15 V:25983). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXH12. Earliest transition date: 2012-02-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXH12 (2012-03-14 V:38980) to DXM12 (2012-03-14 V:42141). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXM12. Earliest transition date: 2012-05-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXM12 (2012-06-15 V:12983) to DXU12 (2012-06-15 V:28352). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXU12. Earliest transition date: 2012-08-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXU12 (2012-09-14 V:16153) to DXZ12 (2012-09-14 V:36450). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXZ12. Earliest transition date: 2012-11-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXZ12 (2012-12-13 V:19357) to DXH13 (2012-12-13 V:20619). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXH13. Earliest transition date: 2013-02-01 | 2013-06-03 08:11:41
LoadContinuousDailyData: Transitioning from DXH13 (2013-03-14 V:36804) to DXM13 (2013-03-14 V:49631). | 2013-06-03 08:11:41
LoadContinuousDailyData: Using DXM13. Earliest transition date: 2013-05-01 | 2013-06-03 08:11:41
[2013-06-03 16:13:46]
it didnt post all of it
[2013-06-03 16:18:12]
i restarted and did nothing else but copy the log.. soybeans is still the chosen one
Software version: 982 | 2013-06-03 11:16:06
Current Service Package: 3 | 2013-06-03 11:16:06
Sierra Chart Historical Data Service is included. | 2013-06-03 11:16:06
Active service: TransAct | 2013-06-03 11:16:06
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-06-03 11:16:06
2013-06-03 11:16:06 Local computer clock time | 2013-06-03 11:16:06
2013-06-03 16:16:06 GMT time | 2013-06-03 11:16:06
2013-06-03 11:16:06 Time zone adjusted time | 2013-06-03 11:16:06
Time difference to server time: 1 seconds. | 2013-06-03 11:16:06
Program path: C:\SierraChart\SierraChartTransActMA\ | 2013-06-03 11:16:06
Data Files path: C:\SierraChart\Data\ | 2013-06-03 11:16:06
OS Version Number: 5.1 | 2013-06-03 11:16:06
Chartbook file not found: C:\SierraChart\Data\Infinity Chart Startup.cht | 2013-06-03 11:16:09
Limiting the number of days back for the continuous futures chart to 3 years based on the account type. | 2013-06-03 11:16:10
Symbols used for GCM13 continuous contract chart: | 2013-06-03 11:16:10
GCM10 | 2013-06-03 11:16:10
GCQ10 | 2013-06-03 11:16:10
GCZ10 | 2013-06-03 11:16:10
GCG11 | 2013-06-03 11:16:10
GCJ11 | 2013-06-03 11:16:10
GCM11 | 2013-06-03 11:16:10
GCQ11 | 2013-06-03 11:16:10
GCZ11 | 2013-06-03 11:16:10
GCG12 | 2013-06-03 11:16:10
GCJ12 | 2013-06-03 11:16:10
GCM12 | 2013-06-03 11:16:10
GCQ12 | 2013-06-03 11:16:10
GCZ12 | 2013-06-03 11:16:10
GCG13 | 2013-06-03 11:16:10
GCJ13 | 2013-06-03 11:16:10
GCM13 | 2013-06-03 11:16:10
Symbols used for DXM13 continuous contract chart: | 2013-06-03 11:16:10
DXM10 | 2013-06-03 11:16:10
DXU10 | 2013-06-03 11:16:10
DXZ10 | 2013-06-03 11:16:10
DXH11 | 2013-06-03 11:16:10
DXM11 | 2013-06-03 11:16:10
DXU11 | 2013-06-03 11:16:10
DXZ11 | 2013-06-03 11:16:10
DXH12 | 2013-06-03 11:16:10
DXM12 | 2013-06-03 11:16:10
DXU12 | 2013-06-03 11:16:10
DXZ12 | 2013-06-03 11:16:10
DXH13 | 2013-06-03 11:16:10
DXM13 | 2013-06-03 11:16:10
Symbols used for ESM13 continuous contract chart: | 2013-06-03 11:16:10
ESM10 | 2013-06-03 11:16:10
ESU10 | 2013-06-03 11:16:10
ESZ10 | 2013-06-03 11:16:10
ESH11 | 2013-06-03 11:16:10
ESM11 | 2013-06-03 11:16:10
ESU11 | 2013-06-03 11:16:10
ESZ11 | 2013-06-03 11:16:10
ESH12 | 2013-06-03 11:16:10
ESM12 | 2013-06-03 11:16:10
ESU12 | 2013-06-03 11:16:10
ESZ12 | 2013-06-03 11:16:10
ESH13 | 2013-06-03 11:16:10
ESM13 | 2013-06-03 11:16:10
Unable to determine the symbols and settings necessary to load $DOWT.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-06-03 11:16:10
Limiting the number of days back for the continuous futures chart to 3 years based on the account type. | 2013-06-03 11:16:13
Symbols used for E6M13 continuous contract chart: | 2013-06-03 11:16:13
E6Z11 | 2013-06-03 11:16:13
E6H12 | 2013-06-03 11:16:13
E6M12 | 2013-06-03 11:16:13
E6U12 | 2013-06-03 11:16:13
E6Z12 | 2013-06-03 11:16:13
E6H13 | 2013-06-03 11:16:13
E6M13 | 2013-06-03 11:16:13
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:13
Chart #5 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:13
Chart #4 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:13
HD Request # 1 - Downloading Intraday chart data for CLN3 to the file CLN3.scid. Service: scsrv | 2013-06-03 11:16:13
HD Request # 1 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:13
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:13
HD Request # 3 - Downloading Historical Daily chart data for $DOWT. Starting date: 2013-05-30. Service: ddf | 2013-06-03 11:16:13
HD Request # 3 - Requesting historical Daily data for $DOWT starting at 2013-05-29 | 2013-06-03 11:16:13
HD Request # 1 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 11:16:13
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:13
The network socket is connected. | 2013-06-03 11:16:13
HD Request # 1 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:13
HD Request # 3 - Receiving historical Daily data for $DOWT starting at 2013-05-29 | 2013-06-03 11:16:14
Writing historical daily data for $DOWT to the file $DOWT.dly | 2013-06-03 11:16:14
Unable to determine the symbols and settings necessary to load $DOWT.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-06-03 11:16:14
Chart #9 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:14
HD Request # 3 - Received 4 records from 2013-05-29 00:00:00 to 2013-06-03 00:00:00 (6.0 days) and wrote 3 records for $DOWT | 2013-06-03 11:16:14
HD Request # 3 - Daily download COMPLETE for $DOWT | 2013-06-03 11:16:14
HD Request # 4 - Downloading Historical Daily chart data for ZS#. Starting date: 2013-05-31. Service: ddf | 2013-06-03 11:16:14
HD Request # 4 - Requesting historical Daily Continuous data for ZSZ10 starting at 2013-05-30 | 2013-06-03 11:16:14
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:14
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:14
HD Request # 1 - Decompressing data. | 2013-06-03 11:16:14
Socket closed. No error. | 2013-06-03 11:16:14
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 11:16:14
HD Request # 4 - Receiving historical Daily data for ZS# starting at 2013-05-30 | 2013-06-03 11:16:14
Writing historical daily data for ZS# to the file ZS#.dly | 2013-06-03 11:16:14
Chart #1 has tagged chart #2 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 11:16:14
Chart #1 has tagged chart #3 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 11:16:14
HD Request # 4 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for ZS# | 2013-06-03 11:16:16
HD Request # 4 - Daily download COMPLETE for ZS# | 2013-06-03 11:16:16
HD Request # 1 - Historical data for CLN3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 11:16:16
HD Request # 1 - Received 0 records and wrote 0 records for CLN3 | 2013-06-03 11:16:16
HD Request # 1 - Intraday download COMPLETE for CLN3 | 2013-06-03 11:16:16
HD Request # 5 - Downloading Intraday chart data for NQM3 to the file NQM3.scid. Service: scsrv | 2013-06-03 11:16:16
HD Request # 5 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:16
HD Request # 5 - Using server: ds4.sierracharts.com port 10049 | 2013-06-03 11:16:16
The network socket is connected. | 2013-06-03 11:16:16
HD Request # 5 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:16
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:16
Chart #9 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:16
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 11:16:16
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:17
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:17
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:17
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 11:16:17
Chart #1 has tagged chart #2 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 11:16:17
Chart #1 has tagged chart #3 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 11:16:17
Chart #2 is performing a full recalculation because it has been tagged. Chartbook: SwingCharts.cht | 2013-06-03 11:16:17
HD Request # 5 - Decompressing data. | 2013-06-03 11:16:17
Socket closed. No error. | 2013-06-03 11:16:17
HD Request # 5 - Historical data for NQM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 11:16:17
HD Request # 5 - Received 0 records and wrote 0 records for NQM3 | 2013-06-03 11:16:17
HD Request # 5 - Intraday download COMPLETE for NQM3 | 2013-06-03 11:16:17
HD Request # 7 - Downloading Intraday chart data for ESM3 to the file ESM3.scid. Service: scsrv | 2013-06-03 11:16:17
HD Request # 7 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:17
HD Request # 7 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 11:16:17
GSP - Port for executable: 55760 | 2013-06-03 11:16:17
GSP - Starting server: C:\SierraChart\SierraChartTransActMA\Transact\TransactToSierraBridge.exe | 2013-06-03 11:16:17
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: SwingCharts.cht | 2013-06-03 11:16:17
The network socket is connected. | 2013-06-03 11:16:17
HD Request # 7 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:17
HD Request # 7 - Decompressing data. | 2013-06-03 11:16:18
Socket closed. No error. | 2013-06-03 11:16:18
HD Request # 7 - Historical data for ESM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 11:16:18
HD Request # 7 - Received 0 records and wrote 0 records for ESM3 | 2013-06-03 11:16:18
HD Request # 7 - Intraday download COMPLETE for ESM3 | 2013-06-03 11:16:18
HD Request # 9 - Downloading Intraday chart data for TFM3 to the file TFM3.scid. Service: scsrv | 2013-06-03 11:16:18
HD Request # 9 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:18
HD Request # 9 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 11:16:18
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 11:16:18
Chart #4 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:18
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:18
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:18
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:18
The network socket is connected. | 2013-06-03 11:16:18
HD Request # 9 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:18
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 11:16:18
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:18
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:19
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:19
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 11:16:19
HD Request # 11 - Downloading Historical Daily chart data for E6H13. Starting date: 2013-03-15. Service: ddf | 2013-06-03 11:16:19
HD Request # 11 - Requesting historical Daily data for E6H13 starting at 2013-03-14 | 2013-06-03 11:16:19
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 11:16:19
HD Request # 9 - Decompressing data. | 2013-06-03 11:16:19
Socket closed. No error. | 2013-06-03 11:16:19
HD Request # 9 - Historical data for TFM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 11:16:19
HD Request # 9 - Received 0 records and wrote 0 records for TFM3 | 2013-06-03 11:16:19
HD Request # 9 - Intraday download COMPLETE for TFM3 | 2013-06-03 11:16:19
HD Request # 12 - Downloading Intraday chart data for YMM3 to the file YMM3.scid. Service: scsrv | 2013-06-03 11:16:19
HD Request # 12 - Starting date and time: 2013-06-03 11:15:46 | 2013-06-03 11:16:19
HD Request # 12 - Using server: ds4.sierracharts.com port 10049 | 2013-06-03 11:16:19
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:19
HD Request # 11 - Receiving historical Daily data for E6H13 starting at 2013-03-14 | 2013-06-03 11:16:19
Writing historical daily data for E6H13 to the file E6H13.dly | 2013-06-03 11:16:19
The network socket is connected. | 2013-06-03 11:16:19
HD Request # 12 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:19
HD Request # 11 - Received 3 records from 2013-03-14 00:00:00 to 2013-03-18 00:00:00 (5.0 days) and wrote 2 records for E6H13 | 2013-06-03 11:16:19
HD Request # 11 - Daily download COMPLETE for E6H13 | 2013-06-03 11:16:19
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:19
HD Request # 14 - Downloading Historical Daily chart data for E6M13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 11:16:19
HD Request # 14 - Requesting historical Daily data for E6M13 starting at 2013-05-30 | 2013-06-03 11:16:19
HD Request # 14 - Receiving historical Daily data for E6M13 starting at 2013-05-30 | 2013-06-03 11:16:19
Writing historical daily data for E6M13 to the file E6M13.dly | 2013-06-03 11:16:19
HD Request # 12 - Decompressing data. | 2013-06-03 11:16:19
HD Request # 14 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for E6M13 | 2013-06-03 11:16:19
HD Request # 14 - Daily download COMPLETE for E6M13 | 2013-06-03 11:16:19
HD Request # 12 - Historical data for YMM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 11:16:19
HD Request # 12 - Received 0 records and wrote 0 records for YMM3 | 2013-06-03 11:16:19
HD Request # 12 - Intraday download COMPLETE for YMM3 | 2013-06-03 11:16:19
HD Request # 15 - Downloading Intraday chart data for 6EM3 to the file 6EM3.scid. Service: scsrv | 2013-06-03 11:16:19
HD Request # 15 - Starting date and time: 2013-06-03 11:15:45 | 2013-06-03 11:16:19
HD Request # 15 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 11:16:19
Chart #5 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:19
HD Request # 17 - Downloading Historical Daily chart data for ESH13. Starting date: 2013-03-14. Service: ddf | 2013-06-03 11:16:19
HD Request # 17 - Requesting historical Daily data for ESH13 starting at 2013-03-13 | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6Z11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Transitioning from E6Z11 (2011-12-16 V:65955) to E6H12 (2011-12-16 V:230604). | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6H12. Earliest transition date: 2012-02-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Transitioning from E6H12 (2012-03-16 V:61899) to E6M12 (2012-03-16 V:254334). | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6M12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Transitioning from E6M12 (2012-06-15 V:63702) to E6U12 (2012-06-15 V:214311). | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6U12. Earliest transition date: 2012-08-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Transitioning from E6U12 (2012-09-14 V:109323) to E6Z12 (2012-09-14 V:329684). | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6Z12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Transitioning from E6Z12 (2012-12-14 V:82323) to E6H13 (2012-12-14 V:254562). | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6H13. Earliest transition date: 2013-02-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Transitioning from E6H13 (2013-03-15 V:68072) to E6M13 (2013-03-15 V:254580). | 2013-06-03 11:16:19
LoadContinuousDailyData: Using E6M13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:19
LoadContinuousDailyData: Reached the end of E6M13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:19
HD Request # 15 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:19
HD Request # 17 - Receiving historical Daily data for ESH13 starting at 2013-03-13 | 2013-06-03 11:16:19
Writing historical daily data for ESH13 to the file ESH13.dly | 2013-06-03 11:16:19
HD Request # 17 - Received 3 records from 2013-03-13 00:00:00 to 2013-03-15 00:00:00 (3.0 days) and wrote 2 records for ESH13 | 2013-06-03 11:16:19
HD Request # 17 - Daily download COMPLETE for ESH13 | 2013-06-03 11:16:19
HD Request # 18 - Downloading Historical Daily chart data for DXH13. Starting date: 2013-03-15. Service: ddf | 2013-06-03 11:16:19
HD Request # 18 - Requesting historical Daily data for DXH13 starting at 2013-03-14 | 2013-06-03 11:16:19
GSP: Connecting to the server localhost. Port 55760 | 2013-06-03 11:16:19
GSP: Connected to server. Waiting to send data. | 2013-06-03 11:16:19
GSP Server Info - Server Name: TransactToSierraBridge . Server Version: 1.1.5 . Provider Name: Transact Futures . | 2013-06-03 11:16:19
GSP - Server protocol version: 1. Client protocol version: 1. There is a protocol match. | 2013-06-03 11:16:19
Transact Futures: Sending logon request. | 2013-06-03 11:16:19
HD Request # 18 - Receiving historical Daily data for DXH13 starting at 2013-03-14 | 2013-06-03 11:16:19
Writing historical daily data for DXH13 to the file DXH13.dly | 2013-06-03 11:16:19
HD Request # 18 - Received 3 records from 2013-03-14 00:00:00 to 2013-03-18 00:00:00 (5.0 days) and wrote 2 records for DXH13 | 2013-06-03 11:16:20
HD Request # 18 - Daily download COMPLETE for DXH13 | 2013-06-03 11:16:20
HD Request # 19 - Downloading Historical Daily chart data for ESM13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 11:16:20
HD Request # 19 - Requesting historical Daily data for ESM13 starting at 2013-05-30 | 2013-06-03 11:16:20
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:20
HD Request # 19 - Receiving historical Daily data for ESM13 starting at 2013-05-30 | 2013-06-03 11:16:20
Writing historical daily data for ESM13 to the file ESM13.dly | 2013-06-03 11:16:20
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:20
HD Request # 19 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for ESM13 | 2013-06-03 11:16:20
HD Request # 19 - Daily download COMPLETE for ESM13 | 2013-06-03 11:16:20
HD Request # 20 - Downloading Historical Daily chart data for DXM13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 11:16:20
HD Request # 20 - Requesting historical Daily data for DXM13 starting at 2013-05-30 | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESM10. Earliest transition date: 2010-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESM10 (2010-06-11 V:1182031) to ESU10 (2010-06-11 V:2234724). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESU10. Earliest transition date: 2010-08-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESU10 (2010-09-10 V:892734) to ESZ10 (2010-09-10 V:1530259). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESZ10. Earliest transition date: 2010-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESZ10 (2010-12-10 V:893224) to ESH11 (2010-12-10 V:1450096). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESH11. Earliest transition date: 2011-02-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESH11 (2011-03-11 V:1125367) to ESM11 (2011-03-11 V:2185696). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESM11. Earliest transition date: 2011-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESM11 (2011-06-10 V:1453530) to ESU11 (2011-06-10 V:2355546). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESU11. Earliest transition date: 2011-08-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESU11 (2011-09-09 V:1615259) to ESZ11 (2011-09-09 V:3165441). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESZ11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESZ11 (2011-12-09 V:1143695) to ESH12 (2011-12-09 V:2410241). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESH12. Earliest transition date: 2012-02-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESH12 (2012-03-09 V:1063406) to ESM12 (2012-03-09 V:1904083). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESM12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESM12 (2012-06-08 V:1334158) to ESU12 (2012-06-08 V:1943155). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESU12. Earliest transition date: 2012-08-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESU12 (2012-09-14 V:1291449) to ESZ12 (2012-09-14 V:2463875). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESZ12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESZ12 (2012-12-14 V:1043852) to ESH13 (2012-12-14 V:1689033). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESH13. Earliest transition date: 2013-02-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from ESH13 (2013-03-08 V:1136905) to ESM13 (2013-03-08 V:1915186). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using ESM13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Reached the end of ESM13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:20
Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:20
HD Request # 20 - Receiving historical Daily data for DXM13 starting at 2013-05-30 | 2013-06-03 11:16:20
Writing historical daily data for DXM13 to the file DXM13.dly | 2013-06-03 11:16:20
HD Request # 20 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for DXM13 | 2013-06-03 11:16:20
HD Request # 20 - Daily download COMPLETE for DXM13 | 2013-06-03 11:16:20
HD Request # 21 - Downloading Historical Daily chart data for GCJ13. Starting date: 2013-04-25. Service: ddf | 2013-06-03 11:16:20
HD Request # 21 - Requesting historical Daily data for GCJ13 starting at 2013-04-24 | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXM10. Earliest transition date: 2010-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXM10 (2010-06-11 V:14703) to DXU10 (2010-06-11 V:34418). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXU10. Earliest transition date: 2010-08-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXU10 (2010-09-10 V:10084) to DXZ10 (2010-09-10 V:19814). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXZ10. Earliest transition date: 2010-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXZ10 (2010-12-10 V:10233) to DXH11 (2010-12-10 V:18914). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXH11. Earliest transition date: 2011-02-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXH11 (2011-03-11 V:14943) to DXM11 (2011-03-11 V:29038). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXM11. Earliest transition date: 2011-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXM11 (2011-06-10 V:19307) to DXU11 (2011-06-10 V:36301). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXU11. Earliest transition date: 2011-08-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXU11 (2011-09-15 V:27356) to DXZ11 (2011-09-15 V:44044). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXZ11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXZ11 (2011-12-15 V:22853) to DXH12 (2011-12-15 V:25983). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXH12. Earliest transition date: 2012-02-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXH12 (2012-03-14 V:38980) to DXM12 (2012-03-14 V:42141). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXM12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXM12 (2012-06-15 V:12983) to DXU12 (2012-06-15 V:28352). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXU12. Earliest transition date: 2012-08-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXU12 (2012-09-14 V:16153) to DXZ12 (2012-09-14 V:36450). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXZ12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXZ12 (2012-12-13 V:19357) to DXH13 (2012-12-13 V:20619). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXH13. Earliest transition date: 2013-02-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from DXH13 (2013-03-14 V:36804) to DXM13 (2013-03-14 V:49631). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using DXM13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Reached the end of DXM13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:20
HD Request # 15 - Decompressing data. | 2013-06-03 11:16:20
Socket closed. No error. | 2013-06-03 11:16:20
HD Request # 15 - Historical data for 6EM3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-06-03 11:16:20
HD Request # 15 - Received 0 records and wrote 0 records for 6EM3 | 2013-06-03 11:16:20
HD Request # 15 - Intraday download COMPLETE for 6EM3 | 2013-06-03 11:16:20
HD Request # 21 - Receiving historical Daily data for GCJ13 starting at 2013-04-24 | 2013-06-03 11:16:20
Writing historical daily data for GCJ13 to the file GCJ13.dly | 2013-06-03 11:16:20
HD Request # 21 - Received 3 records from 2013-04-24 00:00:00 to 2013-04-26 00:00:00 (3.0 days) and wrote 2 records for GCJ13 | 2013-06-03 11:16:20
HD Request # 21 - Daily download COMPLETE for GCJ13 | 2013-06-03 11:16:20
HD Request # 22 - Downloading Historical Daily chart data for GCM13. Starting date: 2013-05-31. Service: ddf | 2013-06-03 11:16:20
HD Request # 22 - Requesting historical Daily data for GCM13 starting at 2013-05-30 | 2013-06-03 11:16:20
HD Request # 22 - Receiving historical Daily data for GCM13 starting at 2013-05-30 | 2013-06-03 11:16:20
Writing historical daily data for GCM13 to the file GCM13.dly | 2013-06-03 11:16:20
HD Request # 22 - Received 3 records from 2013-05-30 00:00:00 to 2013-06-03 00:00:00 (5.0 days) and wrote 2 records for GCM13 | 2013-06-03 11:16:20
HD Request # 22 - Daily download COMPLETE for GCM13 | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCM10. Earliest transition date: 2010-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCM10 (2010-05-27 V:109434) to GCQ10 (2010-05-27 V:138265). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCQ10. Earliest transition date: 2010-07-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCQ10 (2010-07-29 V:54384) to GCZ10 (2010-07-29 V:113129). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCZ10. Earliest transition date: 2010-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCZ10 (2010-11-29 V:94486) to GCG11 (2010-11-29 V:184840). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCG11. Earliest transition date: 2011-01-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCG11 (2011-01-28 V:73023) to GCJ11 (2011-01-28 V:251014). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCJ11. Earliest transition date: 2011-03-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCJ11 (2011-03-29 V:135792) to GCM11 (2011-03-29 V:140893). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCM11. Earliest transition date: 2011-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCM11 (2011-05-27 V:76719) to GCQ11 (2011-05-27 V:138115). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCQ11. Earliest transition date: 2011-07-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCQ11 (2011-07-28 V:70263) to GCZ11 (2011-07-28 V:163995). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCZ11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCZ11 (2011-11-29 V:64786) to GCG12 (2011-11-29 V:158257). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCG12. Earliest transition date: 2012-01-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCG12 (2012-01-30 V:53427) to GCJ12 (2012-01-30 V:133373). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCJ12. Earliest transition date: 2012-03-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCJ12 (2012-03-29 V:47342) to GCM12 (2012-03-29 V:163878). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCM12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCM12 (2012-05-30 V:79887) to GCQ12 (2012-05-30 V:273695). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCQ12. Earliest transition date: 2012-07-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCQ12 (2012-07-30 V:52890) to GCZ12 (2012-07-30 V:111653). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCZ12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCZ12 (2012-11-29 V:65599) to GCG13 (2012-11-29 V:178274). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCG13. Earliest transition date: 2013-01-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCG13 (2013-01-30 V:44893) to GCJ13 (2013-01-30 V:183223). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCJ13. Earliest transition date: 2013-03-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Transitioning from GCJ13 (2013-03-27 V:50450) to GCM13 (2013-03-27 V:179889). | 2013-06-03 11:16:20
LoadContinuousDailyData: Using GCM13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:20
LoadContinuousDailyData: Reached the end of GCM13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:20
Transact Futures: Successfully connected. | 2013-06-03 11:16:26
Starting updates for: $DOWT | 2013-06-03 11:16:26
Starting updates for: NQM3 | 2013-06-03 11:16:26
HD Request # 23 - Downloading Intraday chart data for NQM3 to the file NQM3.scid. Service: scsrv | 2013-06-03 11:16:26
HD Request # 23 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:26
Symbol Error: $DOWT is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Starting updates for: ESM3 | 2013-06-03 11:16:26
HD Request # 23 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 11:16:26
Starting updates for: TFM3 | 2013-06-03 11:16:26
Starting updates for: 6EM3 | 2013-06-03 11:16:26
Starting updates for: YMM3 | 2013-06-03 11:16:26
Starting updates for: ZS# | 2013-06-03 11:16:26
Starting updates for: DXM3 | 2013-06-03 11:16:26
Starting updates for: GCM3 | 2013-06-03 11:16:26
Starting updates for: CLN3 | 2013-06-03 11:16:26
Starting updates for: RJ# | 2013-06-03 11:16:26
Starting updates for: NQ# | 2013-06-03 11:16:26
Starting updates for: YM# | 2013-06-03 11:16:26
Starting updates for: ES# | 2013-06-03 11:16:26
Starting updates for: DY# | 2013-06-03 11:16:26
Starting updates for: NY# | 2013-06-03 11:16:26
Starting updates for: ZB# | 2013-06-03 11:16:26
Starting updates for: ZN# | 2013-06-03 11:16:26
Starting updates for: ZF# | 2013-06-03 11:16:26
Starting updates for: ZT# | 2013-06-03 11:16:26
Starting updates for: UD# | 2013-06-03 11:16:26
Starting updates for: CL# | 2013-06-03 11:16:26
Starting updates for: CB# | 2013-06-03 11:16:26
Starting updates for: NG# | 2013-06-03 11:16:26
Starting updates for: RB# | 2013-06-03 11:16:26
Starting updates for: GC# | 2013-06-03 11:16:26
Starting updates for: SI# | 2013-06-03 11:16:26
Starting updates for: PL# | 2013-06-03 11:16:26
Starting updates for: HG# | 2013-06-03 11:16:26
Starting updates for: DX# | 2013-06-03 11:16:26
Starting updates for: A6# | 2013-06-03 11:16:26
Starting updates for: B6# | 2013-06-03 11:16:26
Starting updates for: D6# | 2013-06-03 11:16:26
Starting updates for: E6# | 2013-06-03 11:16:26
Starting updates for: J6# | 2013-06-03 11:16:26
Starting updates for: N6# | 2013-06-03 11:16:26
Starting updates for: S6# | 2013-06-03 11:16:26
Starting updates for: KC# | 2013-06-03 11:16:26
Starting updates for: CT# | 2013-06-03 11:16:26
Starting updates for: CC# | 2013-06-03 11:16:26
Starting updates for: SB# | 2013-06-03 11:16:26
Starting updates for: LE# | 2013-06-03 11:16:26
Starting updates for: HE# | 2013-06-03 11:16:26
Starting updates for: ZC# | 2013-06-03 11:16:26
Starting updates for: ZW# | 2013-06-03 11:16:26
Starting updates for: ZL# | 2013-06-03 11:16:26
Starting updates for: ZM# | 2013-06-03 11:16:26
Symbol Error: RJ# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: DY# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: NY# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: ZF# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: ZT# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: UD# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: CB# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: RB# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: SI# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: PL# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: HG# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: A6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: B6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: D6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: E6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: J6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: N6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: S6# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: KC# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: CT# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: CC# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: SB# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: LE# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: HE# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: ZL# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
Symbol Error: ZM# is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2013-06-03 11:16:26
The network socket is connected. | 2013-06-03 11:16:26
HD Request # 23 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:26
Starting updates for: FDAXM3 | 2013-06-03 11:16:26
Starting updates for: ZBU3 | 2013-06-03 11:16:26
Starting updates for: GCQ3 | 2013-06-03 11:16:26
Starting updates for: ZSN3 | 2013-06-03 11:16:26
Starting updates for: 6BM3 | 2013-06-03 11:16:26
Starting updates for: 6JM3 | 2013-06-03 11:16:26
Starting updates for: $NSHF | 2013-06-03 11:16:26
SC Market Stats: Connecting to the market data server. | 2013-06-03 11:16:26
Using server: ds4.sierracharts.com, port 443 | 2013-06-03 11:16:26
SC Market Stats - Local market data port: 0 | 2013-06-03 11:16:26
SC Market Stats: Connected to market data server. Now authorizing. | 2013-06-03 11:16:26
SC Market Stats server: Connected. Subscribing to symbols. | 2013-06-03 11:16:27
Restarting real-time data updates for symbol: $NSHF | 2013-06-03 11:16:27
HD Request # 23 - Decompressing data. | 2013-06-03 11:16:27
HD Request # 23 - Receiving Intraday data for NQM3 starting at 2013-06-03 11:15:47 | 2013-06-03 11:16:27
HD Request # 23 - Timestamp of first Intraday data file record written: 2013-06-03 11:15:47 | 2013-06-03 11:16:27
Socket closed. No error. | 2013-06-03 11:16:27
HD Request # 23 - Received 156 records from 2013-06-03 11:15:47 to 2013-06-03 11:16:26 (39.0 seconds) and wrote 156 records for NQM3 | 2013-06-03 11:16:27
HD Request # 23 - Intraday download COMPLETE for NQM3 | 2013-06-03 11:16:27
Real-time intraday chart data file updates started for NQM3 | 2013-06-03 11:16:27
HD Request # 25 - Downloading Intraday chart data for ESM3 to the file ESM3.scid. Service: scsrv | 2013-06-03 11:16:27
HD Request # 25 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:27
HD Request # 25 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 11:16:27
Chart #4 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:27
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:27
The network socket is connected. | 2013-06-03 11:16:27
HD Request # 25 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:27
HD Request # 25 - Decompressing data. | 2013-06-03 11:16:27
HD Request # 25 - Receiving Intraday data for ESM3 starting at 2013-06-03 11:15:47 | 2013-06-03 11:16:27
HD Request # 25 - Timestamp of first Intraday data file record written: 2013-06-03 11:15:47 | 2013-06-03 11:16:27
HD Request # 25 - Received 1033 records from 2013-06-03 11:15:47 to 2013-06-03 11:16:28 (41.0 seconds) and wrote 1033 records for ESM3 | 2013-06-03 11:16:27
HD Request # 25 - Intraday download COMPLETE for ESM3 | 2013-06-03 11:16:27
Real-time intraday chart data file updates started for ESM3 | 2013-06-03 11:16:27
HD Request # 27 - Downloading Intraday chart data for TFM3 to the file TFM3.scid. Service: scsrv | 2013-06-03 11:16:27
HD Request # 27 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:27
HD Request # 27 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 11:16:27
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:27
HD Request # 27 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:27
LoadContinuousDailyData: Using ESM10. Earliest transition date: 2010-05-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESM10 (2010-06-11 V:1182031) to ESU10 (2010-06-11 V:2234724). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESU10. Earliest transition date: 2010-08-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESU10 (2010-09-10 V:892734) to ESZ10 (2010-09-10 V:1530259). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESZ10. Earliest transition date: 2010-11-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESZ10 (2010-12-10 V:893224) to ESH11 (2010-12-10 V:1450096). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESH11. Earliest transition date: 2011-02-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESH11 (2011-03-11 V:1125367) to ESM11 (2011-03-11 V:2185696). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESM11. Earliest transition date: 2011-05-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESM11 (2011-06-10 V:1453530) to ESU11 (2011-06-10 V:2355546). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESU11. Earliest transition date: 2011-08-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESU11 (2011-09-09 V:1615259) to ESZ11 (2011-09-09 V:3165441). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESZ11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESZ11 (2011-12-09 V:1143695) to ESH12 (2011-12-09 V:2410241). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESH12. Earliest transition date: 2012-02-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESH12 (2012-03-09 V:1063406) to ESM12 (2012-03-09 V:1904083). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESM12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESM12 (2012-06-08 V:1334158) to ESU12 (2012-06-08 V:1943155). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESU12. Earliest transition date: 2012-08-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESU12 (2012-09-14 V:1291449) to ESZ12 (2012-09-14 V:2463875). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESZ12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESZ12 (2012-12-14 V:1043852) to ESH13 (2012-12-14 V:1689033). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESH13. Earliest transition date: 2013-02-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Transitioning from ESH13 (2013-03-08 V:1136905) to ESM13 (2013-03-08 V:1915186). | 2013-06-03 11:16:28
LoadContinuousDailyData: Using ESM13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:28
LoadContinuousDailyData: Reached the end of ESM13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:28
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:28
Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:28
HD Request # 27 - Decompressing data. | 2013-06-03 11:16:28
HD Request # 27 - Receiving Intraday data for TFM3 starting at 2013-06-03 11:15:48 | 2013-06-03 11:16:28
HD Request # 27 - Timestamp of first Intraday data file record written: 2013-06-03 11:15:48 | 2013-06-03 11:16:28
Socket closed. No error. | 2013-06-03 11:16:28
HD Request # 27 - Received 222 records from 2013-06-03 11:15:48 to 2013-06-03 11:16:24 (36.0 seconds) and wrote 222 records for TFM3 | 2013-06-03 11:16:28
HD Request # 27 - Intraday download COMPLETE for TFM3 | 2013-06-03 11:16:28
Real-time intraday chart data file updates started for TFM3 | 2013-06-03 11:16:28
HD Request # 29 - Downloading Intraday chart data for 6EM3 to the file 6EM3.scid. Service: scsrv | 2013-06-03 11:16:28
HD Request # 29 - Starting date and time: 2013-06-03 11:15:45 | 2013-06-03 11:16:28
HD Request # 29 - Using server: ds4.sierracharts.com port 10049 | 2013-06-03 11:16:28
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:28
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:28
The network socket is connected. | 2013-06-03 11:16:28
HD Request # 29 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:28
HD Request # 29 - Decompressing data. | 2013-06-03 11:16:28
HD Request # 29 - Receiving Intraday data for 6EM3 starting at 2013-06-03 11:15:46 | 2013-06-03 11:16:28
HD Request # 29 - Timestamp of first Intraday data file record written: 2013-06-03 11:15:46 | 2013-06-03 11:16:28
HD Request # 29 - Received 64 records from 2013-06-03 11:15:46 to 2013-06-03 11:16:29 (43.0 seconds) and wrote 64 records for 6EM3 | 2013-06-03 11:16:28
HD Request # 29 - Intraday download COMPLETE for 6EM3 | 2013-06-03 11:16:28
Real-time intraday chart data file updates started for 6EM3 | 2013-06-03 11:16:28
HD Request # 31 - Downloading Intraday chart data for YMM3 to the file YMM3.scid. Service: scsrv | 2013-06-03 11:16:28
HD Request # 31 - Starting date and time: 2013-06-03 11:15:46 | 2013-06-03 11:16:28
HD Request # 31 - Using server: ds3.sierracharts.com port 10049 | 2013-06-03 11:16:28
HD Request # 31 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:28
HD Request # 31 - Decompressing data. | 2013-06-03 11:16:29
HD Request # 31 - Receiving Intraday data for YMM3 starting at 2013-06-03 11:15:48 | 2013-06-03 11:16:29
HD Request # 31 - Timestamp of first Intraday data file record written: 2013-06-03 11:15:48 | 2013-06-03 11:16:29
Socket closed. No error. | 2013-06-03 11:16:29
HD Request # 31 - Received 157 records from 2013-06-03 11:15:48 to 2013-06-03 11:16:30 (42.0 seconds) and wrote 157 records for YMM3 | 2013-06-03 11:16:29
HD Request # 31 - Intraday download COMPLETE for YMM3 | 2013-06-03 11:16:29
Real-time intraday chart data file updates started for YMM3 | 2013-06-03 11:16:29
HD Request # 33 - Downloading Intraday chart data for CLN3 to the file CLN3.scid. Service: scsrv | 2013-06-03 11:16:29
HD Request # 33 - Starting date and time: 2013-06-03 11:15:47 | 2013-06-03 11:16:29
HD Request # 33 - Using server: ds5.sierracharts.com port 10049 | 2013-06-03 11:16:29
Chart #5 has tagged chart #1 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:29
Chart #1 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:29
The network socket is connected. | 2013-06-03 11:16:29
HD Request # 33 - Requesting up to 30 days of Intraday data. | 2013-06-03 11:16:29
HD Request # 33 - Decompressing data. | 2013-06-03 11:16:29
HD Request # 33 - Receiving Intraday data for CLN3 starting at 2013-06-03 11:15:47 | 2013-06-03 11:16:29
HD Request # 33 - Timestamp of first Intraday data file record written: 2013-06-03 11:15:47 | 2013-06-03 11:16:29
HD Request # 33 - Received 160 records from 2013-06-03 11:15:47 to 2013-06-03 11:16:30 (43.0 seconds) and wrote 160 records for CLN3 | 2013-06-03 11:16:29
HD Request # 33 - Intraday download COMPLETE for CLN3 | 2013-06-03 11:16:29
Real-time intraday chart data file updates started for CLN3 | 2013-06-03 11:16:29
Transact Futures: Requesting Trade positions data. | 2013-06-03 11:16:31
LoadContinuousDailyData: Using DXM10. Earliest transition date: 2010-05-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXM10 (2010-06-11 V:14703) to DXU10 (2010-06-11 V:34418). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXU10. Earliest transition date: 2010-08-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXU10 (2010-09-10 V:10084) to DXZ10 (2010-09-10 V:19814). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXZ10. Earliest transition date: 2010-11-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXZ10 (2010-12-10 V:10233) to DXH11 (2010-12-10 V:18914). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXH11. Earliest transition date: 2011-02-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXH11 (2011-03-11 V:14943) to DXM11 (2011-03-11 V:29038). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXM11. Earliest transition date: 2011-05-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXM11 (2011-06-10 V:19307) to DXU11 (2011-06-10 V:36301). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXU11. Earliest transition date: 2011-08-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXU11 (2011-09-15 V:27356) to DXZ11 (2011-09-15 V:44044). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXZ11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXZ11 (2011-12-15 V:22853) to DXH12 (2011-12-15 V:25983). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXH12. Earliest transition date: 2012-02-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXH12 (2012-03-14 V:38980) to DXM12 (2012-03-14 V:42141). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXM12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXM12 (2012-06-15 V:12983) to DXU12 (2012-06-15 V:28352). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXU12. Earliest transition date: 2012-08-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXU12 (2012-09-14 V:16153) to DXZ12 (2012-09-14 V:36450). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXZ12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXZ12 (2012-12-13 V:19357) to DXH13 (2012-12-13 V:20619). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXH13. Earliest transition date: 2013-02-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from DXH13 (2013-03-14 V:36804) to DXM13 (2013-03-14 V:49631). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using DXM13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Reached the end of DXM13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:33
Chart #7 has tagged chart #6 for full recalculation. Chartbook: Correlation.cht | 2013-06-03 11:16:33
Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Correlation.cht | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6Z11. Earliest transition date: 2011-11-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from E6Z11 (2011-12-16 V:65955) to E6H12 (2011-12-16 V:230604). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6H12. Earliest transition date: 2012-02-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from E6H12 (2012-03-16 V:61899) to E6M12 (2012-03-16 V:254334). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6M12. Earliest transition date: 2012-05-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from E6M12 (2012-06-15 V:63702) to E6U12 (2012-06-15 V:214311). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6U12. Earliest transition date: 2012-08-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from E6U12 (2012-09-14 V:109323) to E6Z12 (2012-09-14 V:329684). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6Z12. Earliest transition date: 2012-11-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from E6Z12 (2012-12-14 V:82323) to E6H13 (2012-12-14 V:254562). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6H13. Earliest transition date: 2013-02-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Transitioning from E6H13 (2013-03-15 V:68072) to E6M13 (2013-03-15 V:254580). | 2013-06-03 11:16:33
LoadContinuousDailyData: Using E6M13. Earliest transition date: 2013-05-01 | 2013-06-03 11:16:33
LoadContinuousDailyData: Reached the end of E6M13 at 2013-06-03. This is the last symbol. | 2013-06-03 11:16:33
Chart #1 has tagged chart #3 for full recalculation. Chartbook: Tradebook.cht | 2013-06-03 11:16:33
Chart #3 is performing a full recalculation because it has been tagged. Chartbook: Tradebook.cht | 2013-06-03 11:16:33
Chart #1 has tagged chart #2 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 11:16:38
Chart #1 has tagged chart #3 for full recalculation. Chartbook: SwingCharts.cht | 2013-06-03 11:16:38
[2013-06-03 16:23:13]
Please contact TransAct support:
http://www.transactfutures.com/ContactUs.htm
You will want to ask for Bob and let them know you are using the newer version.
Sierra Chart is requesting the market data for that symbol. So we do not see any problems with that.
[2013-06-23 20:32:42]
This problem has been resolved and it was due to lowercase characters being used in TransAct symbols. Now when the TransAct software receives a market data request, they uppercase the characters.
Date Time Of Last Edit: 2013-06-23 20:33:01
