Date/Time: Sat, 20 Apr 2024 07:40:00 +0000
NQ Chart Changes to 6E When Changing NQ Tk Size
View Count: 2096
[2013-03-26 17:31:01] |
Disable Global Settings >> General Settings >> General 2 >>Support Symbol Entry from Chart Window
[2013-04-29 02:04:37] |
Bedhog - Posts: 167 |
I also saw this and thought I was doing something wrong. I actually don't want to disable Symbol Entries from the Chart window because I'd like to begin using that feature. However, the problem is length of the CTS symbols. Is there any way to enter a symbol like /6e or @6e to represent this CTS symbol -> CME_Fo-6E-CME_20130600_6EM3 |
[2013-04-29 02:29:52] |
The symbol formats used with CTS T4 in Sierra Chart will be changing. In this particular case the symbol will begin with 6E.
