Date/Time: Sat, 21 Dec 2024 18:23:31 +0000
Marker Use
View Count: 1016
[2015-03-31 14:13:35] |
User94740 - Posts: 333 |
Hi SC, is there a search function in which you can use the marker as the search criteria? thx!
[2015-03-31 17:54:43] |
We do not understand the question.
[2015-03-31 20:07:35] |
sc has a tool called a marker. the marker has a timestamp in the properties info. does sc have a search function which can use the marker according to the timestamps to find all the areas which have been placed with a marker?
[2015-03-31 20:50:36] |
Yes, something like this does exist. Use the Manage Chart Drawings Window: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ManageChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-31 21:47:56] |
great tool! thx! i also have a q regarding any drawing tools. i noticed the horizontal lines i have drawn blot out my chart data. is there a transparency function or way to place the drawing tools in the background?
[2015-03-31 23:55:23] |
The chart drawings can be drawn underneath the price bars. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
