Date/Time: Sat, 21 Dec 2024 18:07:10 +0000
ACSIL - couple of questions related to sub-graphs
View Count: 927
[2015-03-31 06:26:32]
ejtrader - Posts: 688
SC Team - have couple of questions related to sub-graphs.
- Is it possible to find out the number of sub-graphs used in the study? Would like to loop through all the sub-graphs with-in same study to set/reset certain values as needed?
- from the study - Is it possible to dynamically add/drop a sub-graph?
[2015-03-31 08:05:15]
Yes. Sort of. Use sc.NumberOfArrays
Yes you can add and remove a sc.Subgraph simply by setting its Name member to an empty string or to the name you want to have.
