Date/Time: Sat, 21 Dec 2024 18:24:29 +0000
TIME IN FORCE FOR AN STOP ORDER
View Count: 843
[2015-03-30 18:31:10] |
User82615 - Posts: 106 |
WOULD IT BE POSSIBLE TO SET AN STOP ORDER WITH TIME IN FORCE LESS THAT A DAY ? FOR EXAMPLE AN STOP ORDER FOR TIME IN FORCE OF 1 MINUTE? THANK YOU VERY MUCH |
[2015-03-31 03:07:26] |
No, this is not supported unless you were to program this using the Spreadsheet System for Trading study: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
