Date/Time: Sat, 23 Nov 2024 17:05:30 +0000
STOPLIMIT Entry Order and MARKET Order for SL and PT
View Count: 1875
[2013-05-30 12:52:49] |
MSpala - Posts: 5 |
how i can do in ASCIL language when i want to do my entry order is Stop-Limit and my Stoploss and progit target is market order. is this possible? thx Martin |
[2013-05-30 19:16:03] |
You cannot use a market order for a target or a stop.
[2013-07-25 13:13:00] |
TheOddsAreYouDontKnowTheOdds - Posts: 29 |
Dear SC Engineering, Why can you not use a market order for a target? For example, your target is hit and you send out a market order to buy or sell. That should be straightforward. Why is that not possible inside ASCIL? I'm asking because I want to set up a trailing stop function using ASCIL and have it feed/be used by my spreadsheet. I'm just getting started and your response is making me think whether I'm wasting my time. Thanks. |
