Date/Time: Sat, 21 Dec 2024 18:36:06 +0000
Place RSI or MACD at the top of my chart?
View Count: 905
[2015-03-24 16:46:18] |
User623839 - Posts: 108 |
How can I display indicator at the top of my chart with price action below? Or have indicator on top with price action chart in middle and another indicator at the bottom?
[2015-03-24 16:58:40] |
You can control the Chart Region for the main price graph through Chart >> Chart Settings. When setting the main price graph to a Chart Region other than 1, Chart Trading functionality will not work properly and other chart functionality related to the main price graph may not work correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
