Date/Time: Sat, 21 Dec 2024 18:12:17 +0000
Emailed Questions
View Count: 992
[2015-03-24 04:23:58] |
Sierra Chart - Max - Posts: 5756 |
This is a photo of me when using sierra chart, photograph looks like that I had the sell & buy, but in fact it is not, I found this to be simulated, and I do not know how it can be the real deal.
Therefore, the amount of which I saw in my crossland are unchanged But I was able to use real trading in rithmic Sierra Chart Support |
Private File |
[2015-03-24 17:30:28] |
You need to disable Sierra Chart Trade Simulation Mode to do live trading. Here are the instructions: https://www.sierrachart.com/index.php?page=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
