Date/Time: Sun, 29 Dec 2024 07:01:40 +0000
Alert Manager Field Boundary Lines don't stay..
View Count: 846
[2015-03-23 14:37:23] |
The Stealthy Trader - Posts: 185 |
Glad to see that the Alert Manager box now has Field Delineation..or separation of Field Titles. That being said, I adjust the vertical lines every time this box opens only to see that effort quashed next time it opens. This is prob a simple coding script that was left out. I value this enhancement to the Alert Manager box yet not being able to maintain the vertical separation lines is counter productive. Please advise. Thanks as always, Jonathan |
[2015-03-23 18:25:27] |
We will add this capability.
[2016-01-11 12:13:43] |
Marmany - Posts: 307 |
I have recently started to decrease column width in Alert Manager / Alerts Log tab to save screen space. The column width increases as new Alert Text is received to a width greater than necessary to accommodate the text, even though I did Save All after decreasing the width. Was the capability mentioned in #2 added? If affirmative how is it activated? SC v1346 Please advise |
[2016-01-11 17:34:45] |
We will check on this.
[2016-01-26 15:44:17] |
Al SC Developer - Posts: 434 |
The text column normally sets the width so the entire alert message can be seen. In the next version, there is a new option Settings >> Auto Set Alert Text Column Width on the Alert Manager. Toggling this off will disable the function and keep the current widths. |
