Date/Time: Sat, 21 Dec 2024 18:37:18 +0000
ASCIL: Continuous contract and other questions
View Count: 1150
[2015-03-20 15:11:03] |
GmA - Posts: 20 |
Dear Support Board ! I have a few questions: 1. Is there any possiblity to get chart parameters of the chart other then one where the study is running (something similar to the structure s_ACSOpenChartParameters)? My study is loading Basegraph data from other charts but apart of the ChartName I did not find any other information available about parameters of those charts. 2. Is there any possibility to identify using ACSIL that continuous contract has been set on the chart as well as the type of this contract? (That could possibly be also an option to add to the s_ACSOpenChartParameters structure to check/open the charts with the continuous contracts) 3. Is there any possibility to check the Base Graph Draw Type of the chart other then one where the study is running? 4. Is there any possibility to check that the chart other then one where the study is running is a Custom Charts ? 5. My study is running on the chart with another study what creates Custom chart (something similar to Point & Figure). That study is setting sc.IsCustomChart to 1. But when I check sc.IsCustomChart from my study, this value is always equal to 0. Is that a correct behavior or am I doing (or undersatn) something wrongly? Is there any way (apart of the check of sc.BaseGraphGraphDrawType) to identify that study is running on the Custom chart? Thank you very much in advance and Kind regards GmA |
[2015-03-24 16:43:55] |
1. No. 2. We will see about adding this. 3. No. 4. No. 5. This is the correct behavior. Cannot think of a way that the study itself will know it is on a custom chart if it is not creating that custom chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
