Date/Time: Sat, 21 Dec 2024 18:22:29 +0000
Forex Data
View Count: 799
[2015-03-19 19:59:18] |
User39772 - Posts: 311 |
Hello, is it possible to have Forex data on a tick by tick basis with the barchart feed. At the moment when I try to load a currency pair it is loaded via IDEALPRO. |
[2015-03-20 15:45:15] |
We recommend installing another copy of Sierra Chart and use the Forex Data Service. Refer to: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-20 16:45:24] |
Is it possible to use the SC Forex Feed with a connection to IB, i.e. eiter two instances of SC wit barchart feed and one instance of SC with SC Forex feed and both linked to TWS or one instace of SC with Forex feed linked to TWS. |
[2015-03-20 16:52:34] |
When you say "Barchart" feed specifically what are you referring to? It is important to use the terminology that is used on this website. We are not quite sure what you are referring to.
[2015-03-20 17:38:51] |
The Sierra Chart Real-Time and Historical Exchange Data Feed with US Equities enabled.
[2015-03-20 18:15:00] |
This is not really a true Barchart data feed. It is a completely separate service which uses our own software and servers. And direct CME connectivity. For what you want to do, you can use the SC Forex Data feed and use data sharing to access the data in a copy of Sierra Chart connected Interactive Brokers: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
