Date/Time: Sat, 21 Dec 2024 18:38:32 +0000
No black lines
View Count: 951
[2015-03-18 20:13:45] |
User52247 - Posts: 26 |
Hi, What did you explain why i don't have black colors for the lines but i have 2 green ? I have version 1241. see image of the screen. Thank you for your answer alaindua Date Time Of Last Edit: 2015-03-18 20:15:49
no black.JPG / V - Attached On 2015-03-18 20:13:02 UTC - Size: 74.23 KB - 332 views no black.JPG / V - Attached On 2015-03-18 20:13:02 UTC - Size: 74.23 KB - 332 views |
[2015-03-18 20:23:48] |
Refer to the documentation here to change the colors on that menu: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#QuicklyChangingColors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
