Date/Time: Sat, 21 Dec 2024 18:04:53 +0000
Issue With New Changes in Vol Profiles
View Count: 907
[2015-03-18 15:27:43]
Trader Ra - Posts: 87
Hi.. Great work on recent changes to VbP!!
I'm having an issue with using color coding feature together with the new setting 'Highlight Value Area High and Low Only'. The new setting works perfectly if I dont use the color coding feature. The problem seems to be that the new setting is dependent on having Highlight Value Area set to Yes. Without this set to Yes, the new setting doesnt work. Problem is when its set to Yes, the VAH & VAL bars are colored but the entire value area loses the effect of the color coding feature and just stands out as one shade which in turn makes the use of the new setting useless.
So in summary, the new setting does what it should only when the color coding feature is turned off which in effect makes it less useful. The new setting should not be dependent on the entire value area being highlighted.
Hope I explained it well unless Im missing out on some setting here let me know. Thanks.
[2015-03-19 08:59:50]
We understand and this will be solved in the next release.
