Date/Time: Sat, 21 Dec 2024 18:24:37 +0000
FOREX Broker
View Count: 1656
[2015-03-18 08:46:20] |
User41473 - Posts: 21 |
Dear Sierra Support, please I will like to know a Trading Service broker that use Sirera Chart platform for either Only Forex or Forex and Futures apart from FXCM.
[2015-03-18 15:29:17] |
user58907 - Posts: 83 |
If you click File->Data/Trade Service Settings, at the top of the page you get a drop down menu marked "Service". From there you can see which brokers you can connect to which allow trading, as they are clearly marked "trading" or "data". Off hand I see currenex and LMAX which I know are Forex. I am sure some of the others will allow forex and futures, just need to look up their websites. |
[2015-03-18 17:11:03] |
Sierra Chart - Max - Posts: 5756 |
On this page you can find a list up of supported trading services: https://www.sierrachart.com/index.php?page=doc/data.php Sierra Chart Support Date Time Of Last Edit: 2015-03-18 20:09:31
[2015-03-18 20:09:01] |
Have a look at : Open E Cry Interactive Brokers On this page: https://www.sierrachart.com/index.php?page=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
