Date/Time: Sat, 21 Dec 2024 18:36:31 +0000
Linked Charts with SC feed
View Count: 918
[2015-03-16 14:43:28] |
User39772 - Posts: 311 |
Please check the following: open two charts with a different symbol in ech chart, e.g. AAPL[M], FB[M] link them, e.g. L2 update the symbol on one chart window via command e.g. "/MSFT" (see upper chart frame). press enter I would expect that the new symbol is now visible in both charts, but it is not. If I use a quote board, link it via L2 and enter the symbols here the update works fine on both charts. |
[2015-03-16 17:40:42] |
Sierra Chart - Max - Posts: 5756 |
Refer to the Chart Linking documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber If you would like to link the Symbols of two (or more) charts, make sure that Link Symbol option is enabled for the charts. Sierra Chart Support Date Time Of Last Edit: 2015-03-17 01:53:13
