Date/Time: Sat, 21 Dec 2024 18:38:07 +0000
Can't load old symbols (futures contracts)
View Count: 1086
[2015-03-15 15:03:20] |
dem_z - Posts: 14 |
Every time I try and load the ESH5 chart, it just loads ESM5 (current contract). I made a video here (download for HQ): https://www.dropbox.com/s/ug1w2ykkt2s14da/can%27t%20load%20old%20symbols.mov?dl=0 |
[2015-03-15 23:06:07] |
Make sure Chart >> Chart Settings >>Automatically Rollover Futures Symbol is not set.
