Date/Time: Sat, 21 Dec 2024 18:32:51 +0000
how to keep the chart in clear view on all time frames
View Count: 898
[2015-03-11 21:25:44]
User15378 - Posts: 45
hi there, i am wondering if its possible to adjust the scale so that on every time frame the bars are big and plot basically from the top left show the high to the low on the bottom all in the border. i have tried all the scale setting .
because if i get it right on 1 time frame then click say back to the 5 its all squished up and i have to use the range to drag it out again. VERY FRUSTRATING
i dont want to keep moving the chart up or down just keep it plotting inside the border on every time frame.
if there is a way to constantly plot the bars in full view on every time frame PLEASE add this to the new update im sure many people will be pleased.
Thanks alot
[2015-03-11 22:13:26]
Please disregard this a friend sorted it out, i do not know how to delete
[2015-03-12 02:53:24]
Refer to this page for instructions:
https://www.sierrachart.com/index.php?page=doc/helpdetails46.html
You must have changed the scale settings from the default.
