Date/Time: Sat, 21 Dec 2024 18:35:52 +0000
Tick Size is .01 but is updating by .005 and displays incorreclty on chart price scale
View Count: 1172
[2015-03-11 17:40:45] |
User62525 - Posts: 1 |
I"m using the SC Forex Data (FXCM) [data] service. I have the intraday data storage time unit set to 1 tick. This example is for symbol USOil but my charts are doing this regardless of symbol. Global Settings : Price Display format - .01 Tick Size - 0.01 Currency Value Per Tick - .01 I have tried unchecking Overwrite Existing settings and then apply global symbol settings - this didn't change anything. Chart Settings : Price Display format - .01 Tick Size - 0.01 In the Edit>>Edit/Download Data - intraday data menu I see that the Last price level is showing .005 tick size am I missing something here? http://www.sierrachart.com/image.php?l=142609559331.png |
[2015-03-12 03:57:21] |
For what you want to do you need to use the Round Price Bars to Tick Size study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s308 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
