Date/Time: Sat, 21 Dec 2024 18:22:25 +0000
new chart going wild
View Count: 900
[2015-03-10 16:17:30] |
M5amhan - Posts: 468 |
hi, there seems to be a problem when i try opening a new chart, both historical and intraday. everytime i open one from the file tab or even duplicate a chart, the chart being opened flips very quickly between 5 minute and 30 second chart and wont stop. these are the time frames i have set for the other two charts in the chartbook as well. i have disabled any study collections it opens with and any links to anything else and it still does it i attached a picture to get an idea, arrow on the new chart. thanks for any help |
chartgonewild.PNG / V - Attached On 2015-03-10 16:15:49 UTC - Size: 61.09 KB - 353 views |
[2015-03-10 16:35:03] |
Refer to help topic 30.3: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
